I've been trying to convert some MPG files that I have to dvd-video, but can't seem to solve the audio sync problem. It starts off OK, but by about 5 minutes into the video the sound is way ahead of the video. I've tried a few different authoring programs (TMPEG author, Ulead, the NeoDVD that came with the player)-all of them took the mpg files, but none of them managed to burn a watchable DVD. I've cheked the VOB files that are created in PowerDVD, and those are out of sync as well, so it's not a player problem. I've also tried stripping out the audio with VirtualDub, and then using the separate audio stream in the mastering software to no avail.
Any of the research I've done so far seems to indicate that the problem is that the audio in the files I have was encoded at 44.1 kHz, but that DVD needs this to be 48 kHz (since the video is MPEg-2 it should be DVD compliant already). I haven't found a resource that works though, so any help would be appreciated!
Panasonic digicam to mpg puts audio out of sync
By ronhud in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2012, 09:25 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
MPG files play fine on computer, no audio on DVD player
By kenimpzoom in forum Newbie / General discussionsReplies: 9Last Post: 16th Feb 2010, 14:07 -
NO AUDIO in DIVX files made by sub2divx
By etcohod in forum SubtitleReplies: 1Last Post: 16th Dec 2009, 22:44 -
trouble authoring mpg files made in Adobe Premiere Elements 3.0
By compaqted in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2007, 23:14
