    Jan 2004
    Russia,Moscow
    hi there!
    well guys i got a odd problem. the task: avi to vcd.
    source: video - framerate 23.976, audio - mp3
    i used Tmpgenc for encoding video.
    settings:
    NTSCfilm (23.976), CBR 1150, etc ( i clicked "load")
    after film has encoded i try to view it on home dvd player (Lg dk377 - no transcoding). each 5 or 6 secs i get abrupt movement, i mean the picture goes smoothly between those "jerks" and then jerk happens.
    one day, i tryed to make the settings myself. i set up all the settings like
    in NTSCfilm template but i forgot about system tab and left there the "MPEG1 system (automatic)" value. then when i tryed to burn my cd with Nero 6 i got message "the source file not vcd standart" and i pushed the
    "encode" button. when i saw my film, encoded with Nero i didnt see any jerks, i mean all film was going smoothly. the only one "minus" was a picture quality.
    So i dont understand what can make Nero that Tmpgenc cant?
    MOre over, i tryed then MainConcept - the same result - jerks.
    in my case the only one program able to help me it's NERO?
    NERO settings : by default, encode resolution PAL.
    i have a TV with non progressive analysing, PAL. May this setting or fields order in Tmpgenc affect to end result?
    thanks in advance,
    Andrew
  2. Hi, I'm no expert myself. But I think this thread will help you understand better.
    https://www.videohelp.com/forum/viewtopic.php?p=793677#793677
    Software:
    Adobe Premiere Pro - capture stills & motion, edit, render
    Adobe Photoshop 7.0 - edit stills
    TMPGenc Plus 2.5 - encoding, splitting mpeg
    VCDEasy 1.1.5 - stills to mpeg, interactive menu, SVCD cue/bin
    MOTV 2.10
    Nero 5.5.8.2 - burn image
    Jan 2004
    Russia,Moscow
    thx duet for advice.
    but i have solved my problem. the problem was that my dvd player (Lg dk377) doesnt support such a framerate (23.976).
    so, now i need to convert the source framerate to 25 fps and code it in Mpeg.
    hope this thread was helpfull to somebody.
    Andrew.
