Right guys i encoded over 30 - 40 divx/xvid into mpeg and it took like 1 hour and 50mins, Then my computer broken so i had to format now i just grabbed TMPGEnc and wen i go to encode it says 7 hours...wtf it uesed to take just under 2 hours any1 know wot the prob is??
/thanx
Results 1 to 10 of 10
Make sure none of the filters are enabled, they are not all stored in the templates so can get left on and slow things down.
No problem.
Did exactly that myself just a couple of weeks ago. Did one encode with noise reduction enabled, then forgot it was on and wondered why my encodes were so slow! -
You need to SAVE AS TEMPLATE. Then open that template and you'll always have those encoding settings.
Also, don't bother to use MOTION ESTIMATION HIGH or MOTION ESTIMATION HIGHEST instead of MOTION ESTIMATION NORMAL in ADVANCED SETTINGS on TMPGenc. These settings take up gigantor amoutns of extra time and have less effect on the quality of the output MPEG-2 file than the color of my dog's fur. -
They're under Settings->Advanced at the bottomOriginally Posted by jjbodean1970
videoredo takes too long to save ts
By codemaster in forum DVB / IPTVReplies: 6Last Post: 16th Mar 2012, 08:17 -
RipBot264 takes too long 45hours :S
By ripping4life in forum Blu-ray RippingReplies: 0Last Post: 12th Dec 2010, 11:13 -
auto gk takes too long analyzing source
By miguel22 in forum SubtitleReplies: 0Last Post: 18th Nov 2008, 15:01 -
Backing up HD takes too long?
By videobread in forum ComputerReplies: 4Last Post: 26th Jul 2008, 14:17 -
Media takes long time in intializing
By chankya in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Nov 2007, 00:10
