can you make a avi smaller and still be a avi file?I have 2 that I am making a menu for with roxio dvd and it's to big.
Results 1 to 13 of 13
Roxio DVD doesn't have anything to do with AVI's. You can't make a menu for AVI's.
I suspect Roxio is converting the AVI to a DVD compleint MPEG, in which case it will be 2-10 times bigger. That's normal. If it's too big learn how to encode correctly (Roxio is a burning app, not an encoding app, it sucks as an encoder).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
ok so how do I encode the avi files a little smaller..tmpe program makes it into a diff format?
Yes TMPGEnc is an mpeg encoder. If you have an AVI file (I am assuming it is either a divx or xvid file) then you can reencode it with virtualdub with a lower bitrate. Remember though that the quality will be reduced.
i tried virtual dub but it keeps asking for decoder,went nuts looking for 1,got a converter but it still don't work,used pinnacle moviebox usb to make the files.
What codec does pinnacle movie box use. Try opening the file in gspot and see what it says about the codec information.
You need a couple more tools.
Get GSpot to find out WHAT codec you need.
Try the Kristal codec pack, it's got good stable versions of the most common ones.
Once you have those installed, run it through VirtualDub.
You can reduce the filesize two ways. Either lower the bitrate, or reduce the video size...that is, make it smaller dimensions. VirtualDub will do it easily.Cheers, Jim
My DVDLab Guides -
Install this. You can then open your movie in Virtualdub. Also, the only way to lower the file size is to decrease the bitrate. Lowering the resolution will do nothing if the bitrate is not decreased.
I'm not really sure what size you need the AVI to be but you can try using the Divx codec(preferably version 5.05). Use multipass. For the first pass use 8000kbps and for the nth pass use 1200kbps. That should give you decent quality without making it too big. -
I would not reccommen any codec packs, they can screw things up. Only sinstall codecs as and when you need them.Originally Posted by reboot
File size for video is dependant on 2 things, bitrate and duration. Decreasing the resolution will have absolutely no effect on the fiilesize.Originally Posted by reboot
I would agree with teegee, DV AVI video is large, if you want to compress it and maintain it as AVI use either the XVID or DIVX codec. You will be able to compress it down a lot with little to no perceptible quality loss -
Can you elaborate ?Originally Posted by avendo
If you want to create a DVD or CD (VCD) with menus and chapters you cannot keep the files as AVI. They need to be converted to mpeg and then authored to DVD or (S)VCD.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Can I make a AVI file smaller?
By baebbe in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2008, 16:04 -
is there a way to save at a Smaller size avi
By gilnan in forum EditingReplies: 3Last Post: 7th Apr 2008, 16:37 -
How do I make a AVI Smaller?
By gottiman in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2007, 05:35 -
Avi -> Smaller size
By gamerinha in forum Newbie / General discussionsReplies: 6Last Post: 27th Jun 2007, 12:29
