I have recently be using ac3 fix as part of the audio extraction part ov convetrting Xvid's and Divx to DVD. This time ac3fix gave an error indicating that the source could not be read. The following is tjhe file informaton that avicodec indicated:
I'm searching for a way to make this audio readable by ac3fix.
I got to this point by extracting the audio from an AVI using nandub then renaming the extension from wav to ac3 then trying to run ac3fix to make it have the right header. any sugestions will be appreciated.
Thanks in advance,
VC
This is so much fun!
You could try virtualdubmod, streams->stream list->demux. Then you usually doesn't need any ac3fixing.
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 22:59 -
iplayer extracted
By David McMahon in forum EditingReplies: 4Last Post: 7th May 2011, 03:37 -
What do I do with a raw .h264 file extracted from an .mp4 container?
By godfist314 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2008, 13:51 -
Sync issues after fixing with ac3fix
By mub6 in forum AudioReplies: 5Last Post: 24th Dec 2007, 08:56 -
Aften vs Besweet vs Super vs AC3Fix vs working
By awesomer in forum AudioReplies: 2Last Post: 18th Nov 2007, 19:28
