i have been working on this for four monthsand i have tried all i can think of. what i have been doing is tring to capture vcr tapes. i have tried from my dvd also. it has two plugs one out and one in. both of the cables are s cables . the vcr has a converter to s but the dvd does not it is st8 s cable. the drivers it is tring to use are nvidia wdm a/v crossbar nvidia wdm tvaudio crossbar nvidia wdm tv tuner nvidia wdm video capture (universal) the soft ware i have been tring to use is arcsoft showbiz dvd , cap tv tv tool and free vcr version 2.0. ok now the showbiz shows a picture it is white with black lines runnig thought it. when disconnected from source (a vcr ) the lines quit moving but r still there. now when i try the others free vcr and cap tv it says i can not use the device because it's used in another application and then it lists nvidia wdm capture (universal) i have hit control alt delete and checked but i have nothing running. i have had sucess in the past with an ati rage card with capturing in a different system but none with this card and this mainboard. i think it's drivers. but i have deleted all my drivers and reinstalled varuios ways. using my disk, nvidia downloads been all over the net hunting for a fix. if you know somthin im missing or have an idea please help
my system
win 98se o/s
msi kt3 ultra 2ms 6380e
amd 1700 xp
2 120 g seagate 133 7200rpm
512 ddr ram
hp dvd writer 300i
sony cdrom 48x
power color geforce 4 ti 4600 w/vivo 128 ddr ram 4x apg
Results 1 to 1 of 1
Can Nvidia Tuner box be modded to work w/o card?
By perceptionist in forum ComputerReplies: 1Last Post: 6th Nov 2009, 01:48 -
conversion programs just won't work!
By Sean O'Scare in forum Video ConversionReplies: 19Last Post: 17th Feb 2008, 02:58 -
cd drive rw won't work
By sue1951 in forum ComputerReplies: 6Last Post: 27th Aug 2007, 14:39 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 09:37 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 16:36
