Hi,
I'm trying to make cd covers with Nero's Cover Designer but the covers keep printing out on individual sheets of paper. Anyone know how I have it print the front AND back on the same sheet of paper next to each other, so that I can fold them together and insert them as one entity.
If Nero Cover Designer can not do this would you please recommend another program that can and that is fairly simple to use.
Thanks,
rhuala
I guess you are printing cd covers so here goes..
For Plain Paper Setting when you have designed your cover, click on Print Next click on Elements Tab and un-select all except front. Then print it. Then do the same again after turning the paper over but select back .
You will now have the pics on the front and back of the paper.
Or use the Neato CD Booklet setting under Paper Stock That gives you front and back end to end...Not bothered by small problems...
Spend a night alone with a mosquito -
Plus, when you are in the main (design) page, you have to select Neato Cd Booklet Letter or Neato CD Label Letter (or something close to that) in the middle top of the page.
Don't go around saying the world owes you a living. The world owes you nothing. It was here first. - Mark Twain
Tolerance is not a virtue. Only the intolerant demand tolerance of everyone else.
Tayo Yuden Printable and Nero cover design
By alexwick in forum MediaReplies: 5Last Post: 10th Oct 2011, 11:00 -
Sound Designer looking for projects
By KloneZ in forum AudioReplies: 18Last Post: 5th Nov 2010, 15:31 -
Premiere Title Designer - Link Text To Chapter Name
By motown01 in forum EditingReplies: 0Last Post: 6th Oct 2009, 18:10 -
How to make DVD Covers quickly with Nero 8
By vain in forum Newbie / General discussionsReplies: 2Last Post: 5th Apr 2009, 21:06 -
Nero Cover Designer
By kenmo in forum MediaReplies: 6Last Post: 25th Jan 2008, 10:43
