Kind of a strange problem, TMPGENC doesnt want to convert my uncompressed AVI that I had from Adobe Premiere to MPG with sound. Video works fine, but the audio will cut out after half of a second.
Its been working fine for a long time, I didnt install anything or uninstall anything, it just happened it seems. If I convert anything else, it works fine, but AVI is not working. If I transfer over to my other computer, it will convert it fine. Both TMPGENC are the same version 2.5plus and both computers have the same codecs and it seems and all.
Im still looking up more and more faqs but none are working. Thx.
G-spot showed that the uncompressed AVI i was tryin to do was PCM audio.
have you changed the directshow priority lateley? you can both try lower the directshow priority and increase it and then reopen the avi.
www.dvdrhelp.com/tmpgenc#problems (the first problem solution there)
Mouse Dies XP?
By videobread in forum ComputerReplies: 10Last Post: 24th Jun 2012, 01:16 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 09:31 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
