is it possible to make a vcd or svcd that looks like tv.
i'm sick of macro-blocks
say what?
you want to make your video look llike tv quality ??? -
jeomite: tv quality looks better than if you tried to make a ******* vcd out of the divx's floating around on the net.
I think he's trying to say actual picture quality, ie; no blocks, motion blur, etc.
Somebody else will have to get to you on the VCD part, but as far as I'm concerned SVCD created with CCE produces excellent quality. It may not be an ecaxt copy of DVD, but it still looks damn good. AND there's none of that blockiness in your oicture that I think you are actually referring to.
There's more than enough guides & links to guides on this site to get you on your way. -
I never really had bad cases of bad noise blocks when encoding in CCE. You need a high bitrate in order to reduce noise block. And you can also use filters to reduce noise like in TMPGEnc, using its Noise Reduction Filter.
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 19:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 02:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 14:13 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18
