How do you combine a bunch of MPEG's togather as one whole movie.
use a program called tmpgenc and the mpeg tools section in there. it is very simple to join. but you will have to make sure the bite rate is the same on the movies you are joining or they will have to be re encoded to the same settings.
Hope this helps, you can pm me if you need more assistance
modartistModartist
Some are born to rule the world. to live their fantasies.
While most of us just dream,
of what we would like to be. -
You can also do it with Womble https://www.videohelp.com/tools?tool=74#comments
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Thanks for your reply's! Used Womble, works great but after the second MPEG the sound started drifting away from the actually movie. (all about 4 mins long) Sound was about 3 to 4 secs ahead of the video? Any ideas? Put togather about 10 MPEG's.
Go to this recent thread, it deals with that problem.
https://www.videohelp.com/forum/viewtopic.php?t=202522"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
If you are authoring a dvd then its best to leave as separate mpgs and add them all on one track,saves trying to get the files in sync plus they will play all the way thru as one file.
PMT reference help, issues during ad splicing
By explorerst4x4 in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2012, 20:12 -
Splicing WVC-1?
By Tim likes movies in forum EditingReplies: 2Last Post: 21st Feb 2011, 19:54 -
AviSynth Splicing Problems
By legocrazy1 in forum EditingReplies: 7Last Post: 14th Jul 2010, 00:15 -
splicing HD and SD formats together with AviSynth
By PapaDmitry in forum EditingReplies: 2Last Post: 5th Jul 2010, 06:25 -
tape splicing
By CogoSWSDS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 3rd Jan 2008, 08:44
