I'm a complete newbie to the world of DVD production and I've just purchased a Pioneer DVD-RW DVR-106D and am having problems with DVD-RW disks.
I'm using Nero 6.3.0.2 and the same problem occurs on both Arita 2xDVD-RW and on Bulkpaq (Ritek) 2.4xDVD+RW.
Every thing goes OK until it reaches the "lead-out" stage then it just seems to stall and go on and on and on as well as locking up (unable to shut down Nero or eject disk). So far I've only used the DVD-RW's for testing movie files of around 350MB and when I do get the disks out then they play fine. No problems with DVD-R media.
I'm running a P4 1.5Gb with 512Mb Ram and 40Gb spare HDD space.
Any ideas or suggestions would be much appreciated
wow same thing happens to me when i use dvd-rw discs with my lite on 451s....... but dvd-r, dvd+r, and dvd+rw discs work fine..
they just keep going on the leadout track, and wont finish up, having to turn off the computer
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 17:25 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 08:57 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 15:34 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 14:21 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 19:00
