I am using dvd2 avi to convert vob files to d2v files. I then use tmpgenc version 2.5 to encode to mpg. I have all the required settings, codecs and vfapi readers and things installed that I believe I need.
here is a lit of my vfapi box and the priority that is set for each.
VFAPI]
RegisterTMPGEncPlugin=1
AVI.EnableDVCodec411to444=0
AVI.EnableDVCodecColorSpace=0
AVI.DVCodecColorSpace=0
TMPGEnc.Priority=2
TMPGEnc.Enabled=1
AVI.Priority=3
AVI.Enabled=1
VFWAVI.Priority=3
VFWAVI.Enabled=1
GRAPHIC.Priority=0
GRAPHIC.Enabled=1
WAVE.Priority=1
WAVE.Enabled=1
DSHOW.Priority=5
DSHOW.Enabled=1
MSMPEG.Priority=1
MSMPEG.Enabled=1
SONYMPEG.Priority=0
SONYMPEG.Enabled=1
CLMPEG.Priority=0
CLMPEG.Enabled=1
DVD2AVI.Priority=2
DVD2AVI.Enabled=1
LIGOSMPEG.Priority=0
LIGOSMPEG.Enabled=1
m2v.Priority=1
m2v.Enabled=1
I am still not able to load the d2v files in tmpgenc. I have tried changing priorities for all of them. I am lost now. Is there anyone out there that can give me some info on something I might be missing..???/ I have another pc that that runs these same settings and it will load fine in there. My opereating sys is win xp, 1.75 processor, 512 mgs ddr ram, 200 gig h/d
Everything is installed in the same directory as tmpgenc. I have also tried a diff version of tmpgenc and dvd2avi with no results there either. I can't think of any other info that I should post here for my question. If there is something that you need to know to help me. please pm and I will respond right away.
Thank you so much for your help
Modartist 8)
