I want a certian sound clip from a movie, however, if I play it on my DVD player and run a cable into my Line In on my computer, then it has a hissing sound (as if I recoreded it off of my TV, and No, the cable doesn't run through my TV, it goes straight from my DVD to my computer) Is there a program that I can use to capture audio to make soundclips?
As it is a analogue input, the noise is from your PC audio capture card.
You really do need a DVD rom/writer this will resolve the issue, as the audio will be processed digitally.
Your analog input setup should work perfectly. I suspect that you have hardware problems. But if you had a DVD-ROM, then you could simply rip the chapter that had the audio, demux the program elements, convert the .AC3 to .WAV, then play with you new file all you wanted.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
How to cut out clips from DVDs and convert to AVI, MP4 using free software
By Baldrick in forum User guidesReplies: 13Last Post: 13th Dec 2016, 19:33 -
Cut clips from home DVDs and combine them with Pinnacle
By avz10 in forum EditingReplies: 9Last Post: 6th Feb 2010, 15:06 -
Emailing clips from homemade DVDs
By vikasa in forum Video Streaming DownloadingReplies: 4Last Post: 9th Aug 2008, 18:03 -
iMovie HD 6.03 Project: Equalizing sound on movie clips?
By iMacMan in forum MacReplies: 2Last Post: 30th Jan 2008, 03:53 -
Nomalizing sound of many video clips
By davidra in forum AudioReplies: 4Last Post: 6th Sep 2007, 05:13
