Just changed my setup to use the DVMC-DA2 to output to both analog to a video capture card and digital via firewire to a firewire card which allows me to use one source to input analog or digital...
If I connect the VCR output to the DVMC input via s-video and composite audio cables and then connect the DVMC's analog output connections to a video capture card, the video is just passed-through without being affected by any DV encoding process, correct? I'm assuming this is so but wanted to make sure.
Results 1 to 1 of 1
Digital camcorders that have analog pass-thru & TBC
By djnice in forum Capturing and VCRReplies: 30Last Post: 19th Jul 2020, 04:57 -
Canon HV40 analog/digital pass through?
By stantheman1976 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 30th Jun 2011, 07:23 -
Hauppauge card with PAL analog input
By TioSolid in forum Capturing and VCRReplies: 9Last Post: 27th Mar 2009, 21:27 -
mini dv analog recording pass
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Feb 2008, 21:42 -
What is the Best MiniDV Camcorder with analog/digital pass-through
By DigitalGuard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 20th Jun 2007, 15:18
