Hello every one, can you tell me how to monitor the audio input level while capturing. the Audio meter in virtualdub only shows the audio input from the linein, but I using my SB Live's AUX input from AIW radeon.
Thanks for any reply
<font size=-1>[ This Message was edited by: VideoMax on 2001-10-18 20:19:49 ]</font>
should be a way
I can fire up creative recorder and this monitors whatever input I use, aux, linein, microphone etc. Its at start, program files, creative, creative recorder. You have to click the source at top left to change and then click the monitor icon at top right to get it to work.
This software came with my creative live 5.1 and was installed with a full install along with all the other stuff.
I hope you have it installed
Regards
scattergun -
Thanks, that’s a execllent tip! I think that is the only way to monitor the audio input while capturing.
Thanks again.
Dual Input LED Monitor
By blinky88 in forum ComputerReplies: 15Last Post: 28th Apr 2011, 09:23 -
direct display of captured input to monitor
By admaw11 in forum Capturing and VCRReplies: 2Last Post: 8th Jan 2011, 15:31 -
Dual Input display in a single monitor
By torrentkid in forum DVB / IPTVReplies: 1Last Post: 26th Jul 2010, 05:43 -
HDMI, Composite Input to LCD Monitor
By vasudevanb in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2010, 20:54 -
Sigmatel input monitor issues
By GLE3 in forum AudioReplies: 2Last Post: 14th Mar 2009, 15:25
