Hello,
I am a newbie to all of this and have ben building my knowledge of all of this information slowly, but i have come to a stand still when i try to encode my AVI with TMPGEnc, I have decompressed the audio in Virtualdub and that still hasnt worked either, is there any solution?
Thanks for the time and help
I am a complete newbie to all of this, i have been trying to make DVDs for over 2 months now but a problem after problem keeps occuring, could you help me on DVDs or are you only experienced in VCDs and encoding?
Try to be more specific about your problem. Like whether you have problems with the AC3 avi or something. In your first post, you mentioned about having problems encoding your audio, but you did not mentioned whether the avi is AC3 or not.
Anyway, if you are converting a avi with AC3 code to DVD with AC3, try this guide: https://www.videohelp.com/forum/userguides/186739.php -
I originally started by trying to make DVDs, but i could never get the hang of it so i tried to make a VCD, i am really looking for help on how to make a DVD. I have many AVI files which i wud like to get onto DVD+R, I used to convert the files into DVD with TMPGEnc but the file was over 4.7GB when it waz finished, is there any other way of converting AVI to DVD or do i have to somehow shrink the file?
I think you need to do some reading. I suggest you Start here .
Pick a guide that fits your situation and try it. When you run into problems, come back and ask a specific question, giving as much detail as you can about what you have done so far, what has gone wrong and what is your starting point (source files details). Then perhaps someone can help.
AVI (with Ac3 audio) to DVD using TMPGenc 2.5 Plus
By CaptainChaos in forum Authoring (DVD)Replies: 7Last Post: 2nd Mar 2012, 08:03 -
Convert AVI to ? to TMPGEnc DVDAuthor with 5.1 audio
By NDMMackay in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 08:02 -
TMPGEnc Authoring Works 4, no audio with AVI files
By aln688 in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2010, 17:02 -
DVD FLick Audio Encoding Error on AVI videos produced by Canon camera
By patplh in forum Authoring (DVD)Replies: 18Last Post: 14th May 2009, 19:58 -
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 7th Jan 2009, 00:25
