I dont have a clue as to what the hell is going on with this program... I've used it before and it worked fine. But After I wiped my HD and reinstalled windows I cant get it to work properly. I've updated windows and I've installed different versions of DVDshrink(3.0.5 beta, 3.12, and 3.14) but the same problem keeps happening...I'll load the program and it will function at first, but after awhile when I go to start it up again the .exe doesn't respond. At first I thougth that maybe it was the shortcut on the desktop, but the I would go strtaight to the executable and get the same thing. WTF is going on?!?!? I love this program but this is making me nuts.
Somebody please help?
Sounds like a 'lost app'. What operating system? And what do you mean by going back to it? I usually close it after each backup. What you need to do is see if it actually closed. A 'Lost App' is a program that's still running, but doesn't show up on your toolbar. It's taking up resources. I'm not sure how many times you can open Shrink 3.14.
Bittorrent and Netscape clients are notorious for this, you 'close' them but in fact they get minimized but the tool bar won't show them. This also happens when your desktop crashes. Are you getting desktop refreshes? That indicates your OS is crashing.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I am having the same problem. I am still able to use DVD Shrink 3.0 beta 5 and it works fine. I have tried all new versions and it never starts. I have tried uninstalling versions and 3.0 beta 5 is the only one that works.
Im running windows xp. Yeah I closed it out...and I'll go to use the program again and it just wont start. I dont see it running in the background either.
Try what Paj suggested and use the older version because it doesn't require the installation itself. Just copy the exe to your desktop and run from there. Also you might want to completely uninstall the latest version of Shrink if it is on your system.
Hi all.
An identical problem was reported by a couple of DVD Shrink users and the culprit was a virus.
I'm not saying it is the case for you, but I'd strongly suggest you run an up-to-date anti-virus and check.
Crazy Car
By budwzr in forum Off topicReplies: 0Last Post: 18th Nov 2011, 12:31 -
Fans are crazy!!
By alintatoc in forum ComputerReplies: 19Last Post: 4th Jul 2009, 05:13 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Help, I think I am going crazy
By pfxz in forum Off topicReplies: 6Last Post: 3rd Aug 2008, 09:17 -
going crazy with editors
By ellabbs in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2008, 11:06
