I was converting a mpeg2 (VOB) to an .avi in VirtualDub Mod. When I picked my compression, the first time I picked "Uncompressed RGB", and then a second time around, I picked huffyuv 2.1.1.
Now the quality of each looks the same, but the uncompressed is WAY larger. Since huffyuv is a lossless conversion, I figured it would be the same size (or close to) the uncompressed avi.
Can someone clue me in on this. What the difference of the two are, and which is best? ...trying to keep as much quality as possible.
Thank you.
huffyuv is visually lossless (in rgb mode) - and has very low compression.
uncompressed is "uncompressed" ..
they both would produce excellent quality ... you can't really tell the difference (if any) .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
What is uncompressed AVI?
By andrewjameshoward in forum Capturing and VCRReplies: 35Last Post: 2nd Nov 2012, 08:56 -
DVD Recorder vs Huffyuv Uncompressed
By jrodefeld in forum Capturing and VCRReplies: 23Last Post: 11th Jul 2011, 10:22 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
Uncompressed AVI plays back in low quality with WMP12 & Pinnacle Studio 14
By textmagic in forum Software PlayingReplies: 2Last Post: 2nd Apr 2010, 05:25
