Ok, I want to capture 1 hr. programs that I can turn around and burn to VCD. I would like to use Virtualvcr to capture. In that program, what resolution, video settings, and compression should I use if I want to fit 1 hr. of TV programming on a VCD? A lot of guides list the resolutions, but I haven't seen any hard facts on what format to capture into. Is the encoding to the VCD-complaint mpeg-1 done in-line, meaning will it encode it into a file that can be burnt right away? Or after capturing will I then have to encode to VCD compliant format and burn? Are there other processes that have to be done as well? Thanks.
Results 1 to 1 of 1
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 09:46 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 09:05 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 12:01 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 11:00 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 13:22
