Hi
I have a .avi file that I use TMPGEnc plus to convert mpg. Then I use TMPGEnc DVD Author to burn it a DVD. But when I play the DVD on my standalone DVD the movie will play for a while and then it will stop and go back to the main menu. It does so almost every time the dvd to a certain spot in the movie. If it dosenīt go back to the main menu, it will pause for a second and then continue to play the dvd.
The .avi file checks out. No errors. I havenīt check the .mpg file for errors but in windows media player it runs ok.
I have burnt another dvd with the same process and it also gave the same problem. But not at the same time position ( like 10min into the movie). I used diffrent dvd-media, dvd+r and a dvd-r.
Whatīs the problem?
Is it something wtih TMPGEnc or TMPGEnc DVD Author or the dvd-burner or the dvd media?
Results 1 to 1 of 1
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
DVD skips the menu and automatically plays the main movie!
By kreky in forum Authoring (DVD)Replies: 7Last Post: 17th May 2008, 08:14 -
How to back up two main movies of different version with selection menu?
By coody in forum DVD RippingReplies: 3Last Post: 8th Jan 2008, 17:41 -
Can't get back to main menu after movie ends
By rock_king_my in forum DVD RippingReplies: 1Last Post: 8th Dec 2007, 04:12 -
how to burn 2 main movies on one dvd, i have done it but only one plays.
By UmmAddan in forum Video ConversionReplies: 4Last Post: 28th May 2007, 09:54
