  1. My Philips dvd+rw228 collapse a few weeks ago, but guarantee gave me a new LG GSA-4040B DVD±RW/RAM burner. That seem to have been a good exchange to me!
    I got the LG burner today and it was patch with firmware a109. Is there any newer firmware out or is this the latest one?
    Nov 2003
    Ontario, Canada
    The latest firmware version is A302.
  3. Check out: http://gb.lgservice.com
    Under "Device Driver" - "CD-RW" (i know it isn't a CD-RW but that is where is located) and you will see a list of the available firmware.
    Dr-X.
  4. Yes, after some reading I found out that the a3.02 should be the latest firmware. But this a109 that my burner have is not even mentioed, wonder what kind of firmware I have?
    I also find out that nero and recordnow max can't find the burner however it works fine with dvddecryptor. How should get it to work with nero and stomp, any solutions?
    Dec 2001
    No. Calif.
    I don't know about Record Now Max but the Deluxe version works with the 4040b as well as the latest Nero.
