could some one tell me if theres any easy way of unlocking this player so its region free,also what to know if it will play copied -/+ disks.
Thanks in advance.![]()
AFAIK, it needs a firmware update to make it region free.
It should play + or - discs but will probably be a bit picky about the quality of the media. -
Tyr your local independant Panasonic dealers, they might do it for a small fee. Don't bother with the national chains though.Originally Posted by stuart30
it uses a service remote which you can rent from us .... no VAT if you order before noon on 31.1.04
Steve
www.dvdchips.co.uk
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 21:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 21:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15 -
Panasonic AY-DVM83MQ vs. Panasonic AY-DVM83PQ and AY-DVM80XJ question.
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Feb 2008, 13:37
