I've tried to enable DMA on both my drives because they both rip at 1.7x and the Pioneer is supposed to read at 16x. I've done what everyone says by going to device manager but there isn't a checkbox for DMA. I have WIN98SE and the the only thing I could find DMA for was my Hard drive. I've looked under the Hard Disk Controllers that say IDE and can't find the checkbox for DMA either.
Can someone please help me I can't figure it out. Ripping takes sooooo long.
In Windows 98 you go to Device Manager and select the CD-Rom or writer and in the settings tab there will be 6 check boxes (most may be grayed out) and DMA is the last one. YOu should see it as I just checked an old Win98 machine with a CD burner installed and it was checked.
Thats what I did before. There are only five boxes. The sixth one DMA is not there.
DVD Pioneer DV310 - enabling region free
By p_uriel in forum DVD & Blu-ray PlayersReplies: 8Last Post: 30th Jan 2011, 20:10 -
LITE-ON iHES 106 BD-ROM + PowerDVD 8 cannot play Blu-ray disc
By eppingwest in forum Software PlayingReplies: 2Last Post: 23rd Apr 2010, 14:51 -
Enabling Bitsetting on Pioneer DVR 215
By here2rock in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Aug 2008, 05:29 -
My review of the BLU-RAY ROM LITE-ON|DH-4O1S-11
By yoda313 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Dec 2007, 11:57 -
Media Classic Player: Enabling Closed Captioning and Last Scene: for DVD
By hollowman in forum Software PlayingReplies: 1Last Post: 22nd Sep 2007, 07:29
