I have a spindle of Ritek 2x DVD-RW's, and have had nothing but problems.
What is the correct way to:
1) burn an rw for the first time - does it need to be formatted or anything? Can I just do DAO as usual?
2) re-write...do you need to quick erase or thorough erase?
I've read numerous things, but mostly nothing at all. I mostly burn images rather than raw data (i.e. testing DVD writes, etc),
You mean for DVD-Video rather than DVD-ROM?
If that is the case, you should not need to format and quick erase should be fine, thats all I have ever done anyway!
It could well be dodgy/low quality media thats the problem.
DVD rental software (non-commercial for internal usage within company)
By PushPull in forum Newbie / General discussionsReplies: 11Last Post: 16th Nov 2011, 11:20 -
Correct Settings for 16:9 Anamorphic DVD?
By helplessandlost in forum Authoring (DVD)Replies: 0Last Post: 17th Jan 2010, 11:47 -
100% CPU Usage while outputing from TMPGEnc DVD Author
By lj01 in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2008, 10:09 -
HELP--Need Correct Usage Of Bypass Audio Aligment In TsRemux 0.0.2.0
By fast eddie in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2008, 16:42 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 15:09
