Anyone use the ADVC-100 to capture directly to mpeg2?
I'm still a novice when it comes to mine and only use it as it was intended (ie. DV avi), but has anyone manged to use it in conjunction with real time mpeg2 captures?
If so, what success did you have?
What programme and codec?
Many thanks,
Will Hay, hoping he hasn't just asked the dumbest question of the decade![]()
Results 1 to 13 of 13
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Will Hay,
The latest version of the MainConcept standalone encoder has a capture utility that does this. It permits buffering so that you don't get any dropped frames. It also permits VBR encoding and not just CBR like most other apps. As far as quality, you'd have to judge for yourself. I didn't like it very much--but again, I don't like the encodes from the MainConcept encoder in general, which is why I don't use it. There are other apps (e.g. PowerVCR, WinDV, etc.) that do the same. I tried a couple trial versions of these 6 months ago or so, didn't like the results, and deleted them from my system.
In any case, IMO the best quality will always be to capture first to DV, do your editing (which is easy in DV unlike MPEG), and then encode to MPEG. May take a bit longer, but the quality is better, and you've already got the necessary tools.
Just my opinion.
wwaag -
I don't use the Canopus, but I do use an ADS pyro A/V.
Same thing, they're both IEEE boxes.
Intervideo's Winproducer 3 allows you to do this, and it works quite
well. Personally, I prefer going first to DV avi, for editing purposes.
(mpg is not edit friendly) -
Yeah, I'm well aware of the benefits of avi, it's been a long road, it's all I've ever done
I would just like the option to 'capture' mpeg2 when I'm not overly worried that I'm not getting the best I can.
Thanks for the pointers,
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Hey Will, I thought I heard somewhere that Ulead Media Studio Pro 7, Ulead DVD Movie Factory 2, and Pinnacle Studio 8 can also capture MPEG2 directly from a DV source. I have an ADVC-100 on order and I should have it in another couple of weeks. When I get it I will test these apps to see if any of them can do real time MPEG2 captures with the ADVC-100 and report my findings here.
Originally Posted by mracer
Originally Posted by wwaag
mrmungus
Sorry. It's WinDVD Recorder from Intervideo and not WinDV. Like I said, it's been awhile back.
wwaag -
will hay wrote:
Anyone use the ADVC-100 to capture directly to mpeg2?It's probably because of the 4 gb limit I have using WIN98SE.
Will, try MC 1.4 and post results how it works out. I'm curious oin that software/hardware combo
I also have another method to suggest to you, but it'll have to be posted later, can't do it for another week or so. Busy here (but wanting to help).Want my help? Ask here! (not via PM!)
mracer; I've tried Ulead MF 2.0 and just got a lock-up
I have Studio 8 but couldn't see the otpion to change from DV to mpeg2, I'll have another look tonight, thanks.
budz; I know, that's why I created this thread, I hoped you'd check in, you might pick something up
smurfie, and all; thankstgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Can I capture/copy DV directly to DVD MPEG2?
By shina00 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 17th Nov 2011, 06:16 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 01:23 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 13:21 -
By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Mar 2009, 06:21 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 08:15
