Hi, there.
I am doing the best that I can, but I always get two mpg files, no matter how I modify all the settings. Sometimes I don't care about great sound or video quality and don't want ot split a movie.
I use dvd2svcd in avi2vcd mode. I use c.c.e. as the encoder, because it is said to the fastest and the best. But meanwhile I am willing to change to a different program if you are succesful with it.
If anybody of you would teach me the trick please?
Thank you.
Results 1 to 10 of 10
CCE is one of the best for mpeg2(SVCD,DVD) but not mpeg1(vcd).
And if you want 1 movie on 1 cd you must create xvcd, www.kvcd.net has some good templates for tmpgenc for just that. -
Thanks for the information.
Can you tell me this: if I decrease the video bitrate for VCD by 400 to 750, shouldn't I then become much smaller files like I do when I change the bitrates for my mp3? -
VCD is marginal at best. Lowering the bitrate makes it practically unwatchable.
There's nothing you can do to change the size of a VCD from the 80 minutes/CDR.
KVCD is another story, but it uses a different GOP among other things, to achieve more per CDR. It's also non-standard and may have an issue with your player.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Eazy VCD is an easy one click program that can do what you want.
isn't it a "dvd to" only tool? or does it take avi??Originally Posted by hardcoreruss
Encode to mpg1 with 48000 kHz audio mpeglayer2-using TMPGenc or MainConcept to a single file.
Create DVD on HD with Ulead DVD MF- no menu-only chapters
Use DVDShrink to reduce total movie to less than 695 MB
Burn the AUDIO_TS and VIDEO_TS folders to CD as data with Nero
You have a miniDVD of the movie on a single CD!!
Works quite well for upto 120 min movies without difficult to code parts. -
but it doesn't work on most dvd players.Originally Posted by mgh
He did not specify that his original file was an avi, I took it as he was coming straight from a dvd.Originally Posted by Baldrick
No it does not take avi files.
Converting VOBs from a DVD to a single AVI
By aln688 in forum Video ConversionReplies: 25Last Post: 6th Apr 2010, 09:34 -
Converting several flv videos into a single DVD video with ConvertXtoDVD4
By Codonauta in forum Video ConversionReplies: 2Last Post: 17th Feb 2010, 20:31 -
Converting Multiple Chapter DVDs into one single MP4 file
By djfreex2 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 14:02 -
Converting Bi-Lingual VCDs to Single Language MPEGs
By HHBear in forum Video ConversionReplies: 3Last Post: 13th Feb 2008, 23:05 -
Converting DVD to single MPEG2
By nagihcim1 in forum Newbie / General discussionsReplies: 4Last Post: 5th Sep 2007, 16:55
