Is is possible to select part of a DVD and convert it to avi format? I am interested in converting a 5 minute segment of a DVD about 40 minutes into the movie and converting it without going through the process of converting the whole 2 1/2 DVD. Can this be done and could someone recommend the easiet way to do this. Thanks
I also want to know how to make a certain part of a DVD into AVI or mpeg. Anyone....thanks
fairuse 0.3 looks pretty good, set start and end(english version also available):
for more tools click on www.dvdrhelp.com/tools and select dvd to avi/divx/xvid. -
Is this for ripping part of a DVD or cutting an AVI file? I'm interested in finding out jow to ripping a small part of a DVD.
What is wrong with the above suggestion? It would appear to do what you require?
When someone gives you a link for an app to do the job you need to do you should actually click on the link to see what it will do and even if there isnt a link do a search for the app that was mentioned.
Thanks Baldrick,
This is one I haven't played around with yet. Forgot all about it."It is not enough to obey Big Brother. You must love him".
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
converting the audio part of a video (for xbox)
By vidm in forum Video ConversionReplies: 6Last Post: 28th May 2010, 22:16 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07
