I follow exactly wat the tutorial says but there this 1 avi i can convert to vcd. I just begginning to convert my avi. So far I had only tried to convert 2 avi. the first one was a success. The second one is driving me crazy. i tried extracting the audio with vdub. that didn't help. i then tried to just use the same audio/video. that didn't work. I just can't figure out wat i am doing wrong that causing the video and audio to be out of sync. i am using the latest tmpgenc pro. runnin on
2.4ghz 678mb of ram winxp pro.
Is it out of sync after you have authored or after you have burned
i went into vdub video>scan video stream for errors and this is what it display.
Delete the bad frames and it should be in sync.
https://www.videohelp.com/forum/userguides/153907.php -
call me blind but all i see are sequence. 012345678901234657890 etc....
where are the bad frame. I checked it twice and didn't find any.....
Bad Frame Report from VirtualDub-Mp3
Frame # 55482
Frame # 55483
Frame # 55484
Frame # 55485
Frame # 55486
Frame # 55487
Frame # 55488
Frame # 55489
Frame # 55490
Frame # 55491
Frame # 55492
Frame # 55493
Frame # 55494
Frame # 55495
Frame # 55496
Frame # 55497
Frame # 55498
Frame # 55499
Frame # 55500
Frame # 55501
Frame # 55502
Frame # 55503
Frame # 55504
Frame # 55505
Frame # 55506
Frame # 55507
Frame # 55508
Frame # 55509
Frame # 55510
Frame # 55511
Frame # 55512
Frame # 55513
Frame # 55514
Frame # 55515
Frame # 55516
Frame # 55517
Frame # 55518
Frame # 55519
Frame # 55520
Frame # 55521
Frame # 55522
Frame # 55523
Frame # 55524
Frame # 55525
Frame # 55526
Frame # 55527
Frame # 55528
Frame # 55529
Frame # 55530
Frame # 55531
Frame # 55532
Frame # 55533
Frame # 55534
Frame # 55535
Frame # 55536
Frame # 55537
Frame # 55538
Frame # 55539
Frame # 55540
Frame # 55541
Frame # 55542
Frame # 55543
Frame # 55544
Frame # 55545
Frame # 55546
Frame # 55547
Frame # 55548
Frame # 55549
Frame # 55550
Frame # 55551
Frame # 55552
Frame # 55553
Frame # 55554
Frame # 55555
Frame # 55556
Frame # 55557
Frame # 55558
Frame # 55559
Frame # 55560
Frame # 55561
Frame # 55562
Frame # 55563
Frame # 55564
Frame # 55565
Frame # 55566
Frame # 55567
Frame # 55568
Frame # 55569
Frame # 55570
Frame # 55571
Frame # 55572
Frame # 55573
Frame # 55574
Frame # 55575
Frame # 55576
Frame # 55577
Frame # 55578
Frame # 55579
Frame # 55580
Frame # 55581
Frame # 55582
Frame # 55583
Frame # 55584
Frame # 55585
Frame # 55586
Frame # 55587
Frame # 55588
Frame # 55589
Frame # 55590
Frame # 55591
Frame # 55592
Frame # 55593
Frame # 55594
Frame # 55595
Frame # 55596
Frame # 55597
Frame # 55598
Frame # 55599
Frame # 55600
Frame # 55601
Frame # 55602
Frame # 55603
Frame # 55604
Frame # 55605
Frame # 55606
Frame # 55607
Frame # 55608
Frame # 55609
Frame # 55610
Frame # 55611
Frame # 55612
Frame # 55613
Frame # 55614
Frame # 55615
Frame # 55616
Frame # 55617
Frame # 55618
Frame # 55619
Frame # 55620
Frame # 55621
Frame # 55622
Frame # 55623
Frame # 55624
Frame # 55625
Frame # 55626
Frame # 55627
Frame # 55628
Frame # 55629
Frame # 55630
Frame # 55631
Frame # 55632
Frame # 55633
Frame # 55634
Frame # 55635
Frame # 55636
Frame # 55637
Frame # 55638
Frame # 55639
Frame # 55640
Frame # 55641
Frame # 55642
Frame # 55643
Frame # 55644
Frame # 55645
Frame # 55646
Frame # 55647
Frame # 55648
Frame # 55649
Frame # 55650
Frame # 55651
Frame # 55652
Frame # 55653
Frame # 55654
Frame # 55655
Frame # 55656
Frame # 55657
Frame # 55658
Frame # 55659
Frame # 55660
Frame # 55661
Frame # 55662
Frame # 55663
Frame # 55664
Frame # 55665
Frame # 55666
Frame # 55667
Frame # 55668
Frame # 55669
Frame # 55670
Frame # 55671
Frame # 55672
Frame # 55673
Frame # 55674
Frame # 55675
Frame # 55676
Frame # 55677
Frame # 55678
Frame # 55679
Frame # 55680
Frame # 55681
Frame # 55682
Frame # 55683
Frame # 55684
Frame # 55685
Frame # 55686
Frame # 55687
Frame # 55688
Frame # 55689
Frame # 55690
Frame # 55691
Frame # 55692
Frame # 55693
Frame # 55694
Frame # 55695
Frame # 55696
Frame # 55697
Frame # 55698
Frame # 55699
Frame # 55700
Frame # 55701
Frame # 55702
Frame # 55703
Frame # 55704
Frame # 55705
Frame # 55706
Frame # 55707
Frame # 55708
Frame # 55709
Frame # 55710
Frame # 55711
Frame # 55712
Frame # 55713
Frame # 55714
Frame # 55715
Frame # 55716
Frame # 55717
Frame # 55718
Frame # 55719
Frame # 55720
Frame # 55721
Frame # 55722
Frame # 55723
Frame # 55724
Frame # 55725
Frame # 55726
Frame # 55727
Frame # 55728
Frame # 55729
Frame # 55730
Frame # 55731
Frame # 55732
Frame # 55733
Frame # 55734
Frame # 55735
Frame # 55736
Frame # 55737
Frame # 55738
Frame # 55739
Frame # 55740
Frame # 55741
Frame # 55742
Frame # 55743
Frame # 55744
Frame # 55745
Frame # 55746
Frame # 55747
Frame # 55748
Frame # 55749
Frame # 55750
Frame # 55751
Frame # 55752
Frame # 55753
Frame # 55754
Frame # 55755
Frame # 55756
Frame # 55757
Frame # 55758
Frame # 55759
Frame # 55760
Frame # 55761
Frame # 55762
Frame # 55763
Frame # 55764
Frame # 55765
Frame # 55766
Frame # 55767
Frame # 55768
Frame # 55769
Frame # 55770
Frame # 55771
Frame # 55772
Frame # 55773
Frame # 55774
Frame # 55775
Frame # 55776
Frame # 55777
Frame # 55778
Frame # 55779
Frame # 55780
Frame # 55781
Frame # 55782
Frame # 55783
Frame # 55784
Frame # 55785
Frame # 55786
Frame # 55787
Frame # 55788
Frame # 55789
Frame # 55790
Frame # 55791
Frame # 55792
Frame # 55793
Frame # 55794
Frame # 55795
Frame # 55796
Frame # 55797
Frame # 55798
Frame # 55799
Frame # 55800
Frame # 55801
Frame # 55802
Frame # 55803
Frame # 55804
Frame # 55805
Frame # 55806
Frame # 55807
Frame # 55808
Frame # 55809
Frame # 55810
Frame # 55811
Frame # 55812
Frame # 55813
Frame # 55814
Frame # 55815
Frame # 55816
Frame # 55817
Frame # 55818
Frame # 55819
Frame # 55820
Frame # 55821
Frame # 55822
Frame # 55823
Frame # 55824
Frame # 55825
Frame # 55826
Frame # 55827
Frame # 55828
Frame # 55829
Frame # 55830
Frame # 55831
Frame # 55832
Frame # 55833
Frame # 55834
Frame # 55835
Frame # 55836
Frame # 55837
Frame # 55838
Frame # 55839
Frame # 55840
Frame # 55841
Frame # 55842
Frame # 55843
Frame # 55844
Frame # 55845
Frame # 55846
Frame # 55847
Frame # 55848
Frame # 55849
Frame # 55850
Frame # 55851
Frame # 55852
Frame # 55853
Frame # 55854
Frame # 55855
Frame # 55856
Frame # 55857
Frame # 55858
Frame # 55859
Frame # 55860
Frame # 55861
Frame # 55862
Frame # 55863
Frame # 55864
Frame # 55865
Frame # 55866
Frame # 55867
Frame # 55868
Frame # 55869
Frame # 55870
Frame # 55871
Frame # 55872
Frame # 55873
Frame # 55874
Frame # 55875
Frame # 55876
Frame # 55877
Frame # 55878
Frame # 55879
Frame # 55880
Frame # 55881
Frame # 55882
Frame # 55883
Frame # 55884
Frame # 55885
Frame # 55886
Frame # 55887
Frame # 55888
Frame # 55889
Frame # 55890
Frame # 55891
Frame # 55892
Frame # 55893
Frame # 55894
Frame # 55895
Frame # 55896
Frame # 55897
Frame # 55898
Frame # 55899
Frame # 55900
Frame # 55901
Frame # 55902
Frame # 55903
Frame # 55904
Frame # 55905
Frame # 55906
Frame # 55907
Frame # 55908
Frame # 55909
Frame # 55910
Frame # 55911
Frame # 55912
Frame # 55913
Frame # 55914
Frame # 55915
Frame # 55916
Frame # 55917
Frame # 55918
Frame # 55919
Frame # 55920
Frame # 55921
Frame # 55922
Frame # 55923
Frame # 55924
Frame # 55925
Frame # 55926
Frame # 55927
Frame # 55928
Frame # 55929
Frame # 55930
Frame # 55931
Frame # 55932
Frame # 55933
Frame # 55934
Frame # 55935
Frame # 55936
Frame # 55937
Frame # 55938
Frame # 55939
Frame # 55940
Frame # 55941
Frame # 55942
Frame # 55943
Frame # 55944
Frame # 55945
Frame # 55946
Frame # 55947
Frame # 55948
Frame # 55949
Frame # 55950
Frame # 55951
Frame # 55952
Frame # 55953
Frame # 55954
Frame # 55955
Frame # 55956
Frame # 55957
Frame # 55958
Frame # 55959
Frame # 55960
Frame # 55961
Frame # 55962
Frame # 55963
Frame # 55964
Frame # 55965
Frame # 55966
Frame # 55967
Frame # 55968
Frame # 55969
Frame # 55970
Frame # 55971
Frame # 55972
Frame # 55973
Frame # 55974
Frame # 55975
Frame # 55976
Frame # 55977
Frame # 55978
Frame # 55979
Frame # 55980
Frame # 55981
Frame # 55982
Frame # 55983
Frame # 55984
Frame # 55985
Frame # 55986
Frame # 55987
Frame # 55988
Frame # 55989
Frame # 55990
Frame # 55991
Frame # 55992
Frame # 55993
Frame # 55994
Frame # 55995
Frame # 55996
Frame # 55997
Frame # 55998
Frame # 55999
Frame # 56000
Frame # 56001
Frame # 56002
Frame # 56003
Frame # 56004
Frame # 56005
Frame # 56006
Frame # 56007
Frame # 56008
Frame # 56009
Frame # 56010
Frame # 56011
Frame # 56012
Frame # 56013
Frame # 56014
Frame # 56015
Frame # 56016
Frame # 56017
Frame # 56018
Frame # 56019
Frame # 56020
Frame # 56021
Frame # 56022
Frame # 56023
Frame # 56024
Frame # 56025
Frame # 56026
Frame # 56027
Frame # 56028
Frame # 56029
Frame # 56030
Frame # 56031
Frame # 56032
Frame # 56033
Frame # 56034
Frame # 56035
Frame # 56036
Frame # 56037
Frame # 56038
Frame # 56039
Frame # 56040
Frame # 56041
Frame # 56042
Frame # 56043
Frame # 56044
Frame # 56045
Frame # 56046
Frame # 56047
Frame # 56048
Frame # 56049
Frame # 56050
Frame # 56051
Frame # 56052
Frame # 56053
Frame # 56054
Frame # 56055
Frame # 56056
Frame # 56057
Frame # 56058
Frame # 56059
Frame # 56060
Frame # 56061
Frame # 56062
Frame # 56063
Frame # 56064
Frame # 56065
Frame # 56066
Frame # 56067
Frame # 56068
Frame # 56069
Frame # 56070
Frame # 56071
Frame # 56072
Frame # 56073
Frame # 56074
Frame # 56075
Frame # 56076
Frame # 56077
Frame # 56078
Frame # 56079
Frame # 56080
Frame # 56081
Frame # 56082
Frame # 56083
Frame # 56084
Frame # 56085
Frame # 56086
Frame # 56087
Frame # 56088
Frame # 56089
Frame # 56090
Frame # 56091
Frame # 56092
Frame # 56093
Frame # 56094
Frame # 56095
Frame # 56096
Frame # 56097
Frame # 56098
Frame # 56099
Frame # 56100
Frame # 56101
Frame # 56102
Frame # 56103
Frame # 56104
Frame # 56105
Frame # 56106
Frame # 56107
Frame # 56108
Frame # 56109
Frame # 56110
Frame # 56111
Frame # 56112
Frame # 56113
Frame # 56114
Frame # 56115
Frame # 56116
Frame # 56117
Frame # 56118
Frame # 56119
Frame # 56120
Frame # 56121
Frame # 56122
Frame # 56123
Frame # 56124
Frame # 56125
Frame # 56126
Frame # 56127
Frame # 56128
Frame # 56129
Frame # 56130
Frame # 56131
Frame # 56132
Frame # 56133
Frame # 56134
Frame # 56135
Frame # 56136
Frame # 56137
Frame # 56138
Frame # 56139
Frame # 56140
Frame # 56141
Frame # 56142
Frame # 56143
Frame # 56144
Frame # 56145
Frame # 56146
Frame # 56147
Frame # 56148
Frame # 56149
Frame # 56150
Frame # 56151
Frame # 56152
Frame # 56153
Frame # 56154
Frame # 56155
Frame # 56156
Frame # 56157
Frame # 56158
Frame # 56159
Frame # 56160
Frame # 56161
Frame # 56162
Frame # 56163
Frame # 56164
Frame # 56165
Frame # 56166
Frame # 56167
Frame # 56168
Frame # 56169
Frame # 56170
Frame # 56171
Frame # 56172
Frame # 56173
Frame # 56174
Frame # 56175
Frame # 56176
Frame # 56177
Frame # 56178
Frame # 56179
Frame # 56180
Frame # 56181
Frame # 56182
Frame # 56183
Frame # 56184
Frame # 56185
Frame # 56186
Frame # 56187
Frame # 56188
Frame # 56189
Frame # 56190
Frame # 56191
Frame # 56192
Frame # 56193
Frame # 56194
Frame # 56195
Frame # 56196
Frame # 56197
Frame # 56198
Frame # 56199
Frame # 56200
Frame # 56201
Frame # 56202
Frame # 56203
Frame # 56204
Frame # 56205
Frame # 56206
Frame # 56207
Frame # 56208
Frame # 56209
Frame # 56210
Frame # 56211
Frame # 56212
Frame # 56213
Frame # 56214
Frame # 56215
Frame # 56216
Frame # 56217
Frame # 56218
Frame # 56219
Frame # 56220
Frame # 56221
Frame # 56222
Frame # 56223
Frame # 56224
Frame # 56225
Frame # 56226
Frame # 56227
Frame # 56228
Frame # 56229
Frame # 56230
Frame # 56231
Frame # 56232
Frame # 56233
Frame # 56234
Frame # 56235
Frame # 56236
Frame # 56237
Frame # 56238
Frame # 56239
Frame # 56240
Frame # 56241
Frame # 56242
Frame # 56243
Frame # 56244
Frame # 56245
Frame # 56246
Frame # 56247
Frame # 56248
Frame # 56249
Frame # 56250
Frame # 56251
Frame # 56252
Frame # 56253
Frame # 56254
Frame # 56255
Frame # 56256
Frame # 56257
Frame # 56258
Frame # 56259
Frame # 56260
Frame # 56261
Frame # 56262
Frame # 56263
Frame # 56264
Frame # 56265
Frame # 56266
Frame # 56267
Frame # 56268
Frame # 56269
Frame # 56270
Frame # 56271
Frame # 56272
Frame # 56273
Frame # 56274
Frame # 56275
Frame # 56276
Frame # 56277
Frame # 56278
Frame # 56279
Frame # 56280
Frame # 56281
Frame # 56282
Frame # 56283
Frame # 56284
Frame # 56285
Frame # 56286
Frame # 56287
Frame # 56288
Frame # 56289
Frame # 56290
Frame # 56291
Frame # 56292
Frame # 56293
Frame # 56294
Frame # 56295
Frame # 56296
Frame # 56297
Frame # 56298
Frame # 56299
Frame # 56300
Frame # 56301
Frame # 56302
Frame # 56303
Frame # 56304
Frame # 56305
Frame # 56306
Frame # 56307
Frame # 56308
Frame # 56309
Frame # 56310
Frame # 56311
Frame # 56312
Frame # 56313
Frame # 56314
Frame # 56315
Frame # 56316
Frame # 56317
Frame # 56318
Frame # 56319
Frame # 56320
Frame # 56321
Frame # 56322
Frame # 56323
Frame # 56324
Frame # 56325
Frame # 56326
Frame # 56327
Frame # 56328
Frame # 56329
Frame # 56330
Frame # 56331
Frame # 56332
Frame # 56333
Frame # 56334
Frame # 56335
Frame # 56336
Frame # 56337
Frame # 56338
Frame # 56339
Frame # 56340
Frame # 56341
Frame # 56342
Frame # 56343
Frame # 56344
Frame # 56345
Frame # 56346
Frame # 56347
Frame # 56348
Frame # 56349
Frame # 56350
Frame # 56351
Frame # 56352
Frame # 56353
Frame # 56354
Frame # 56355
Frame # 56356
Frame # 56357
Frame # 56358
Frame # 56359
Frame # 56360
Frame # 56361
Frame # 56362
Frame # 56363
Frame # 56364
Frame # 56365
Frame # 56366
Frame # 56367
Frame # 56368
Frame # 56369
Frame # 56370
Frame # 56371
Frame # 56372
Frame # 56373
Frame # 56374
Frame # 56375
Frame # 56376
Frame # 56377
Frame # 56378
Frame # 56379
Frame # 56380
Frame # 56381
Frame # 56382
Frame # 56383
Frame # 56384
Frame # 56385
Frame # 56386
Frame # 56387
Frame # 56388
Frame # 56389
Frame # 56390
Frame # 56391
Frame # 56392
Frame # 56393
Frame # 56394
Frame # 56395
Frame # 56396
Frame # 56397
Frame # 56398
Frame # 56399
Frame # 56400
Frame # 56401
Frame # 56402
Frame # 56403
Frame # 56404
Frame # 56405
Frame # 56406
Frame # 56407
Frame # 56408
Frame # 56409
Frame # 56410
Frame # 56411
Frame # 56412
Frame # 56413
Frame # 56414
Frame # 56415
Frame # 56416
Frame # 56417
Frame # 56418
Frame # 56419
Frame # 56420
Frame # 56421
Frame # 56422
Frame # 56423
Frame # 56424
Frame # 56425
Frame # 56426
Frame # 56427
Frame # 56428
Frame # 56429
Frame # 56430
Frame # 56431
Frame # 56432
Frame # 56433
Frame # 56434
Frame # 56435
Frame # 56436
Frame # 56437
Frame # 56438
Frame # 56439
Frame # 56440
Frame # 56441
Frame # 56442
Frame # 56443
Frame # 56444
Frame # 56445
Frame # 56446
Frame # 56447
Frame # 56448
Frame # 56449
Frame # 56450
Frame # 56451
Frame # 56452
Frame # 56453
Frame # 56454
Frame # 56455
Frame # 56456
Frame # 56457
Frame # 56458
Frame # 56459
Frame # 56460
Frame # 56461
Frame # 56462
Frame # 56463
Frame # 56464
Frame # 56465
Frame # 56466
Frame # 56467
Frame # 56468
Frame # 56469
Frame # 56470
Frame # 56471
Frame # 56472
Frame # 56473
Frame # 56474
Frame # 56475
Frame # 56476
Frame # 56477
Frame # 56478
Frame # 56479
Frame # 56480
Frame # 56481
Frame # 56482
Frame # 56483
Frame # 56484
Frame # 56485
Frame # 56486
Frame # 56487
Frame # 56488
Frame # 56489
Frame # 56490
Frame # 56491
Frame # 56492
Frame # 56493
Frame # 56494
Frame # 56495
Frame # 56496
Frame # 56497
Frame # 56498
Frame # 56499
Frame # 56500
Frame # 56501
Frame # 56502
Frame # 56503
Frame # 56504
Frame # 56505
Frame # 56506
Frame # 56507
Frame # 56508
Frame # 56509
Frame # 56510
Frame # 56511
Frame # 56512
Frame # 56513
Frame # 56514
Frame # 56515
Frame # 56516
Frame # 56517
Frame # 56518
Frame # 56519
Frame # 56520
Frame # 56521
Frame # 56522
Frame # 56523
Frame # 56524
Frame # 56525
Frame # 56526
Frame # 56527
Frame # 56528
Frame # 56529
Frame # 56530
Frame # 56531
Frame # 56532
Frame # 56533
Frame # 56534
Frame # 56535
Frame # 56536
Frame # 56537
Frame # 56538
Frame # 56539
Frame # 56540
Frame # 56541
Frame # 56542
Frame # 56543
Frame # 56544
Frame # 56545
Frame # 56546
Frame # 56547
Frame # 56548
Frame # 56549
Frame # 56550
Frame # 56551
Frame # 56552
Frame # 56553
Frame # 56554
Frame # 56555
Frame # 56556
Frame # 56557
Frame # 56558
Frame # 56559
Frame # 56560
Frame # 56561
Frame # 56562
Frame # 56563
Frame # 56564
Frame # 56565
Frame # 56566
Frame # 56567
Frame # 56568
Frame # 56569
Frame # 56570
Frame # 56571
Frame # 56572
Frame # 56573
Frame # 56574
Frame # 56575
Frame # 56576
Frame # 56577
Frame # 56578
Frame # 56579
Frame # 56580
Frame # 56581
Frame # 56582
Frame # 56583
Frame # 56584
Frame # 56585
Frame # 56586
Frame # 56587
Frame # 56588
Frame # 56589
Frame # 56590
Frame # 56591
Frame # 56592
Frame # 56593
Frame # 56594
Frame # 56595
Frame # 56596
Frame # 56597
Frame # 56598
Frame # 56599
Frame # 56600
Frame # 56601
Frame # 56602
Frame # 56603
Frame # 56604
Frame # 56605
Frame # 56606
Frame # 56607
Frame # 56608
Frame # 56609
Frame # 56610
Frame # 56611
Frame # 56612
Frame # 56613
Frame # 56614
Frame # 56615
Frame # 56616
Frame # 56617
Frame # 56618
Frame # 56619
Frame # 56620
Frame # 56621
Frame # 56622
Frame # 56623
Frame # 56624
Frame # 56625
Frame # 56626
Frame # 56627
Frame # 56628
Frame # 56629
Frame # 56630
Frame # 56631
Frame # 56632
Frame # 56633
Frame # 56634
Frame # 56635
Frame # 56636
Frame # 56637
Frame # 56638
Frame # 56639
Total of 1158 bad frames found.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05
