i have a athlon xp 2000 in one of my computers and i wanna get more ram but i wanna get pc2700 (on sale) but i think the 2000 suppose to take pc2100....... well my question is will it cause any conflicts or troubles in my system ?????????
Should not pose a problem what-so-ever. You will just be running your RAM at a lower speed than it is certified to run. Besides -- the CPU does not really determin compatibility (assuming that the RAM is at least certified/rated to the CPU fsb speed). Compatibiity is really a function of the motherboard. Either way you are probably fine - as a BIOS update would resolve it if needed.
PC-2700 = 333MHz (166x2)
PC-2100 = 266MHz (133x2) -
Why not go for PC3200 RAM so you can transfer it to a new PC if you upgrade? It should still work no problem, and it's only a few quid more expensive.
CobraDMX
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
what kind of discs should I be using?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 4th Dec 2008, 00:15 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31 -
What kind of gamer are you?
By yoda313 in forum PollsReplies: 21Last Post: 6th Aug 2007, 18:18
