hi.
first of all english is not my language so excuse me for any wrong in grammar or words.
here is my problem.
I have for ex 1 movie divided in three svcd files. I place the files in correct 1order in a folder. chose the folder in svcddvd, but when I push start the program changes the order of the files.
ex in the folder
svcd1a
svcd1b
svcd1c
but the program changes to
1b
1a
1c
the same problem occur when I have different movies in 4 svcd files. svcd2dvd mixes the two movies even though they are in the correct order from the start
I hope this made any sence to you and look forward to any solution
drutten
Hi, Drutten!
(If it is D. Rutten, you might be Belgian. Or Dutch, like me..
You should have a good look at my extensive description of how to get everything right, and in the right order, at:
https://www.videohelp.com/forum/viewtopic.php?t=194602
Especially the Steps 1, 3, 8 and 9.
The Filing System writes the files onto disk in the sequence in which the user puts them there, which is not necessarily the sequence the user sees in, for instance, the Windows Explorer. There they are sorted by name. Or Extension, Size, Type, Date, Time, Attribute, whatever the user wishes.
Programs, like SVCD2DVD and others, however, do not access the Windows Explorer for their file information, but the Filing System, which provides them with the original, "historical" sequence. SVCD2DVD then uses this info UNLESS it gets later instructions from the user under the Author Tab.
That is why I advise people to make a NEW Folder (with a simple name) and move the files to it IN SEQUENCE from their original location(s).
Should anything still go wrong, then follow Step 8 to correct it.
Callan -
thank you so much
now it is working as it should do. by the way, drutten is anickname my real name is anette and I am from sweden.
thanks again for an exellent guide
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 17:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 20:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 09:35 -
DV - Frames out of order
By devonuto in forum EditingReplies: 3Last Post: 25th Jan 2008, 02:45 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
