i need to downsample a 448kbps ac3 file to 384kbps.
i've done this a while ago,but for some reason AC3Machine wont 'give me ac3!'
i even installed the ac3filter,which i dont use.
what else can convert ac3 to ac3?
Yes, Besweet, but use AC3Machine as a front end...
Go to http://www.doom9.org/index.html?/ , and find the audio guides that get you .AC3 to .AC3..
Good luck!!!! -
I use Sonic Foundry's Vegas 4.0 (I guess sony owns it now) and got the AC3 plug in for it. I noticed when using the free ware tools that the AC3 is not compliant, and I am not sure if they fixed that. But Sonic Foundry's conversion is aces, and works great. Really easy to use and has some other FX and stuff you can do.
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 05:18 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
