  1. Ok, I have a ripped VOB file. Using womble's mpeg-vcr, I demux'ed it, and got a .mpv & .mpa stream. Then I demux'ed it with tmpgenc plus and got a .m2v & .ac3 stream! Now this is the same VOB file, why are these programs giving me different streams? (no settings have been touched in either program).
    The audio stream is a .ac3, so i don't get why womble gave me a .mpa (or is it the same?)
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Same thing, different file extensions. As you now know, different programs tend to use different extensions. For instance, if I create an mpeg-2 movie using Canopus Procoder the extension will be m2p. Also, an older version of the ATI Multimedia Center capture software used to create mpeg-2 movies with an mp2 extension.
  3. Yes there are different extensions for mpeg audio and video, but ac3 is dolby audio, which is a completely different compression format from mpeg audio (mpa.)
    I haven't used mpeg-vcr in a while, but I remember it has a setting where you can designate the audio for editing re-encoding as mpeg or ac3. But that shouldn't affect demuxing.
    Weird. I'd stick to tmpgenc plus for your demuxing in the future.
