I just ripped and Incoded a movie to PAl.
Now I have a movie in .mpg format.
I can't find what I should do next in order for it to play in a DVD player.
check out this link, it should help out.
http://www.vcdhelp.com/burnmpg.htm
also, basically burn it using the techiniques offered in the above link and have a dvd player that will play svcd.
Assuming you encoded it to the svcd format, if you encoded it to the vcd format then a player that will accept the vcd format.
you can check your manual for the player or the dvd player list on the left to see if your player will do such.
hope this helps,
TW
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 10:45 -
Quick AVIdemux question!
By janlafata in forum EditingReplies: 16Last Post: 17th Mar 2009, 02:19 -
Quick laptop tv out question
By Tidy in forum ComputerReplies: 3Last Post: 28th Jul 2008, 15:42 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 17:38 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 08:21
