Hey there, on certain dvd's I still have a problem with subtitles auto triggering on the dvd player even though I selected no subtitles during the re-authoring. The most recent one that comes to mind is Harry Potter I.
Am I doing something wrong? Like I said it hasn't happened on every dvd I've made, but I always select no subtitles...
Thanks,
John
He asked a question.. You didn't answer
DID YOU RE AUTHOR
or
SHRINK the whole thing
These are the TWO MODES SHRINK works in
Which did you use
I had this problem myself on 2 TITLES and never figured out why....
Don't remember..but I believe I shunk the whole thing ((HONEY))
What had you done? -
In preferences there's an option to hide/show small streams. This needs to be configured correctly. Subtitles are very small and some will not even be listed unless this option is configured correctly.
I had this problem before.. I found this on the site somewhere else and use it still when authoring the main movie only. This will fix it and its real simple. Use Ifoedit for it.
With IFOEdit, open VIDEO_TS.IFO/VMGM_MAT/First Play PGC.
Right click on 1.Pre Command
Choose Insert Command
Choose edit command
Select (SetSTN)Set Subpicture Stream Nr Stream = 0
Save file.
This will turn off the subtitles at startup.
Converting mvk from 1080 to 720 with Ripbot leaves hard subtitles
By Glave in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jun 2010, 03:36 -
What is it that triggers my Samsung Plasma...
By StaffanC in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2009, 09:27 -
DVD Shrink subtitles
By juststarting in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2009, 19:01 -
How to get Shrink to auto open Imgburn?
By PGibbons in forum Newbie / General discussionsReplies: 3Last Post: 12th Jun 2008, 23:15 -
subtitles auto on
By badboy2351 in forum SubtitleReplies: 1Last Post: 14th May 2007, 08:05
