My pvr250 worked fine until I upgraded my video card to an ATI Radeon 9600 Series. When the ATI driver is loaded, the Hauppauge WinTv PCI II driver will not start (This device cannot start. (Code 10)). If I boot the machine with a default VGA driver the pvr250 driver loads fine. Has anyone run into a problem with their pvr250 and an ATI Radeon series video card?
I've tried moving the pvr250 to other slots, changed IRQ's in the BIOS all with no luck. I've also tried several different driver version for both the pvr250 and the ATI card.
If I boot with a default vga driver, the pvr250 driver starts. If I then install the ATI drivers without a reboot, they both work. Once I reboot, the pvr250 driver will not start again.
Any ideas or suggestions would be appreciated.
welll being the only thing you update was ATI drivers I say it the ATI drivers that are root of your problem.
Hauppauge pvr usb2 driver problem after XP install....
By pinetop in forum Capturing and VCRReplies: 14Last Post: 3rd Jul 2010, 01:35 -
Clean uninstall of ATI AIW 9600
By justin81 in forum Capturing and VCRReplies: 3Last Post: 23rd Dec 2009, 11:41 -
Can Radeon 9600 Pro run fullHD (1080p)?
By GeraDOT in forum DVB / IPTVReplies: 10Last Post: 12th May 2009, 07:09 -
ATI ALL in WONDER 9600 TV & capturing problem
By ikeogut in forum Capturing and VCRReplies: 35Last Post: 31st Aug 2008, 05:51 -
Hauppauge and ATI in same PC
By chris1379 in forum Media Center PC / MediaCentersReplies: 2Last Post: 13th Jun 2007, 21:40
