i need help converting my .sub files to .srt files. because i have somehow made that i cant play .sub files anymore, doesnt even matter if i uninstall vobsub and then reinstall, it wont help, the icon of my .sub files is a txt doc. there must be someway too change it back?? or i appreciate a program that can convert sub to srt... when i try to load my .sub files in example: Subtitle Workshop or Subtitle Studio, its says that it is an unsupported format or a bad file??![]()
normally must sub files are ???? . srt.txt files ( the full extension) go to my computor click on tools folder options , click on view uncheck the box " hide extensions for known file types" and apply. Now right click on ur subtile file and go to properties here u should now be able to see the full file extension rename it as ?? .srt file. now u have an srt file .
good luck
How to demux .srt from mkv, then convert .srt to .smi and mux .smi to mkv??
By narayanan in forum SubtitleReplies: 1Last Post: 7th Aug 2010, 22:49 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 00:46 -
SRT SUB
By sg999 in forum SubtitleReplies: 13Last Post: 2nd May 2009, 22:27 -
Working with .sup and .srt
By ma2kp in forum SubtitleReplies: 2Last Post: 8th Dec 2008, 21:34 -
.sub to.srt?
By Hank Kinsley in forum SubtitleReplies: 9Last Post: 14th Aug 2007, 12:25
