  1. Every since I reformated almost all of my dvd's burn halfway. Thats not the only problem. Instant copy gets errors all the time. This also happens with DVDxcopy express. Anyone have any ideas as to what the hell is wrong?
  2. Blacksmith
    I`M NOT SURE OF WHAT SYSTEM YOU HAVE BUT IT SOUNDS LIKE SOFTWARE CONFLICTS THERE IS A LIST OF PROGRAMS YOU HAVE TO REMOVE OR DISABLE FOR DVD X COPY TO WORK
    I HAD A MINOR PROBLEM WITH DVD X COPY PLATINUM WHEN I FORMATTED MY PC
    BUT USE THIS LINK http://forum.321studios.com/?f=48&m=6148&g=6154#m6154
    iT WILL GIVE YOU A LIST OF CONFLICTING PROGRAMS THAT DVD X COPY DOES NOT RUN WITH
    HOPE THIS HELPS
    PS GIVE MORE INFO ON YOUR SYSTEM AS THIS IS HELPFUL WHEN TRYING TO GIVE ADVICE
    FILL IN YOUR PC PROFILE IT MAKES IT ALOT EASIER
  3. I have a Athalon 1700xp with 3 hard drives. Geforce 4 4200 ti video card. I have a sony burner. It always worked great until I reformated. Now nothing works when it comes to burning dvd's. I would say it works 1 out of 5 burns and I dont do anything different.
  4. Blacksmith
    as my previous response said check convlicting software with the link i gave you if you are running antivirus software alot of burning programs dont like this as your virus software checks for virus during the burn procees and causes errors when your writer is trying to perform a writing disc mode
    so use the link i supply
    because if you have any programs like listed below this will cause the problems
    software that know to cause problems with dvd x copy
    1NORTONS ANTIVURS
    2ANY ANTIVIRUS SOFTWARE
    3 B`CLIPS UDF PACKUNG WRITING SOFTWARE
    4 IN CD UDF PACKING WRITING SOFTEWARE COMES WITH NERO
    THERE ARE MANY OTHERS
    BUT USE THE LINK TO CHECK THEM OUT
    THE LINK AGAIN IShttp://forum.321studios.com/?f=48&m=6148&g=6154#m6154
    PS CHECK YOU HAVE A ASPI DRIVER INSTALL AND DMA MODE IS APPLY TO YOUR DVD DRIVE
    IF NOT SURE SEARCH THE NET AND DOWNLOAD ASPI SRIVER FOR YOUR OPERATING SYSTEM(OS)
    TO CHECK IF DMA MODE IS APPLY ASK A FRIEND WHO IS ADVANCE USER IT IS SIMPLY TO DO
    GOOD LUCK
  5. What is wrong with your caps lock key ?
    ALL CAPITALS is considered shouting...
