Hi, I just bought the OPTORITE DD0203 and works great. The only problem I am having is that the dvd's it writes wont play on my xbox. They will play on my dvd player. My buddy has the NEC ND-1100A and the dvd's it writes will work on my xbox. I updated my firmware and it still wont work. Is there anything I can do? or can you tell me why it don't work? Thanks
what are you writing them with? If Nero, check that you check that box for 'force xbox compatibility mode'.
Or search this forum for 'xbox'... -
My X-box was picky about the media it did play Kypermedia but was very choppy at the end of the movie. Maxell played very good on the X-box I burned DVD-R please always say that you are burning DVD-R or DVD+R. I think X-Box might not read DVD+R but I might be wrong.
Samsung tv wont read subtitles
By BigAl77 in forum SubtitleReplies: 15Last Post: 9th Sep 2016, 13:59 -
DVD+RW Wont Be Read
By WoH-George in forum DVD & Blu-ray RecordersReplies: 8Last Post: 26th Jun 2011, 14:28 -
Datawrite disc wont read on pc and laptop
By lb77 in forum DVD RippingReplies: 3Last Post: 11th Nov 2009, 10:20 -
Disk wont read
By rheming3 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Dec 2008, 02:03 -
@^DVD-Roms wont Read Dual Layer^@
By Varchasve in forum Newbie / General discussionsReplies: 13Last Post: 20th Sep 2007, 20:13
