No problemOriginally Posted by Fairhope.
You can try a system restore before doing a reinstall. Just boot from your Windows XP CD-ROM and choose to do a repair when prompted. If this is successful I would reinstall the SP1a and check WindowsUpdate.By the way, I did uninstall the Sony drive and tried to re-boot normally and in safe-mode. No luck.
Results 31 to 37 of 37
"By the way, I did uninstall the Sony drive and tried to re-boot normally and in safe-mode."
What exact computer is this?
Anyway, did you try pushing f8 ? hold that when you turn on the computer & a restore menu may comeup along with a safe menu. as mentioned above you can also use the cd if you inform the bios to boot from it. -
BTW, in this forum you can find information to help you recover from a serious crash.
Originally Posted by handyguy
Igalan:
Many thanks for link. The document it leads to pretty much nails my situation. I've saved it as a Word document and printed it off. I'll be trying it out before my last resort of reinstalling the OS. This document needs to come standard with all WinXP applications. -
Originally Posted by igalan
I believe my WinXP Rescue program is similar ...
After reading how it works ... I did the same thing. I used the floppy disk made with WinRescue ... got into DOS.
Used the program to take me back to most recent backup ... I then used Windows Restore to get me to the most recent backup made.
Of course ... there was some program or two that didn't work and I had to re-install them ... but WINXP Rescue did work ... it's a good program.
Just make sure to make the Floppy Disks and keep them safe from external damage. -
Originally Posted by ViRaL1
I remember reading something about flashing a drive like that from DOS, but I can't remember much about it now.
For a new drive Pioneer and Sony are both good I hear.
Good luck.
Sony BDP-S370: Firmware upgrade to 567 and region free hack
By Nosh3 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jan 2011, 07:57 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 06:50 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52 -
How to do firmware upgrade for a DVD Player
By Tiger_Lion in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2007, 00:33 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 11:00
