Hey everyone...
I have a little problem that I can't seem to get just right. I have been converting some of my anime to SVCDs in the past and I am just now starting to enter the world of converting to DVDs. The problem I have been having is that my tv has REALLY bad overscan on it, so if I encode leaving the apsect ratios set at both the same for input and output as well as using "keep aspect ratio" the video looks okay, but the subtitles run off of the screen really bad. In another thread, Elmark suggested some "custom" resolutions to use for SVCD conversion to battle this problem. I used what he suggested and tweaked it slightly because of my specific tv. Basically what I came up with for a 24 minute 4:3 episode AVI encoded with a resolution of 640x480 originally, is a custom size of 432x448 and for a 16:9 episode with a resolution of 640x360, I ended up using a custom size of 432x336. These both seem to work out very well for my particular tv.
Now.... these are custom sizes for the SVCDs that I have been making. Since DVDs have a much higher resolution to them than SVCDs, does anyone happen to know what I might be able to use for custom size resolution to encode with that will give me a video that is in proportion as well as with subtitles that don't run off the screen? Also, if you have any ideas for the custom sizes of CVDs, that would be great too, as I am thinking about making these as well.
Thanks so much!!
--Jeff H.![]()
Results 1 to 1 of 1
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08 -
DVD Editing - "Smoothness" Issues
By xd00d in forum EditingReplies: 29Last Post: 28th Jan 2008, 15:34 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 17:20 -
VCR Overscan Issues ("jittery" line at top of screen)
By jcm0320 in forum Capturing and VCRReplies: 14Last Post: 24th Aug 2007, 13:56
