Hi All,
I hadn't done so in a long time, but had recently capped some Analog captures.
I am running them through avisynth into CCE to resize, encode, etc to author them out.
I have gone through avisynth's site, to try and find a line command to brighten the clips. I was hoping someone may know it.
Any help, as always is greatly appreciatedThanks guys
Results 1 to 9 of 9
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
http://www.avisynth.org/index.php?page=Tweak
So you might try:
Tweak(Bright=10)
or something like that, depending on how dark the source is. However, if your script also adds black bars, it'll brighten them up as well. You can get around that by adding the AddBorders line (if there is one) after Tweak. Or you might want to play around with Levels also, to adjust the Gamma:
http://www.avisynth.org/index.php?page=Levels -
Thank you very much !!!!!!!!! I'll give it a go ASAP
Thanks again
~~~Spidey~~~
Hi Guys,
I did review the avisynth pages above,a nd have tried multiple variances of the script....no luck, so I am sure I am simply entering something wrong...
My base script is -
# -= AviSynth script by FitCD v1.1.2 =-
#LoadPlugin("D:\PathOf\AnyPlugin.dll")
AviSource("H:\005.avi")
LanczosResize(688,448)
AddBorders(16,16,16,16)
#Trim(0,11468).FadeOut(150)
With my additions I made it -
ConverttoYUY2
Tweak(clip "H:\005.avi" [, float 0] [, float 0] [, float 20] [, float 3] [, bool 0])
No luck - the page references this line -
Tweak(clip clip [, float hue] [, float sat] [, float bright] [, float cont] [, bool coring])
I also had added the Convertto YUY2 (from my RGB source) as it said Tweak could only work on YUY clips.
Again, any help would be very appreciated
Thanks !!!!
~~~Spidey~~~
Please, someone out there I know knows the answer to this scripting issue. If anyone can help shed some more light on it I'd really appreciate it. Thanks !!!
~~~Spidey~~~
Just a few things out of place with this script, not totally sure if you used the script exactly the way you posted but here would be a better way to make that script work.Code:
# -= AviSynth script by FitCD v1.1.2 =- #LoadPlugin("D:\PathOf\AnyPlugin.dll") AviSource("H:\005.avi") ConverttoYUY2 Tweak(clip "H:\005.avi" [, float 0] [, float 0] [, float 20] [, float 3] [, bool 0]) LanczosResize(688,448) AddBorders(16,16,16,16) #Trim(0,11468).FadeOut(150)
Based on what you typedCode:AviSource("H:\005.avi") ConverttoYUY2() Tweak(0.0, 1.0, 2.0, 3.0) #Hue, Sat, Brght, Cntrst LanczosResize(688,448) AddBorders(16,16,16,16)
I read 20 as 2.0 and 3 as 3.0#Tweak( float 0] [, float 0] [, float 20] [, float 3] [, bool 0])
The script above will increase the brightness and contrast.
Looking in the AVS documention for 2.5 I can't see anything in Tweak that requires a bool value, so I don't know why you had the bool value at the end of the Tweak filter; could be wrong though because I haven't used 2.0 in a long time.
Your video must be REALLY dark if you're going to be increasing the brightness and contrast at the same time. Especially with a value of 3.0 for contrast; basically increasing the contrast by 30%.
Better put the shades 8) on. But yeah just play with the Tweak values and see what works for you; I usually leave a comment underneath tweak to help me remember what each value adjusts; just fyi 0.0 and 1.0 are the defaults for Hue and Sat respectively and so they aren't adjusted in the script. -
Try adding just this:
tweak(bright=10)
Adjust the number until you are satisfied with the results. Ver2.53 adds a boolean "coring" value to the script.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
@SLK001
You learn something new everyday; just adjusting what you want without having to worry about other values. I didn't add anything to his script, just edited his.
@spidey
An even better version of your script thanks to the help of manono and as restated by SLK001.
Code:AviSource("H:\005.avi") ConverttoYUY2() Tweak(Bright=20.0, Cont=3.0) LanczosResize(688,448) AddBorders(16,16,16,16) -
Thank you very much manono, deadpac, & SLK001
I appreciate it extremely much !!!! I will give it all a go and revise the script.
It'll help me get these caps cleaned up. I haven't been on the board much of late as we had a little Spidey
The clips I've capped, to author out are all our movies, Hospital, kids' first Christmas, etc., so again I can not tell you how much I appreciate your help.
Thanks again !!!!
~~~Spidey~~~
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 08:29 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 21:37 -
Avisynth Script Help
By jamhat in forum Video ConversionReplies: 2Last Post: 29th Nov 2009, 06:13 -
Avisynth script
By daz2712 in forum Video ConversionReplies: 2Last Post: 19th Aug 2009, 11:08 -
avisynth script
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Sep 2007, 11:29
