For a while i've been useing a Pioneer DVR-104 drive and Princo 1x DVD-Rs for www.allmediaoutlet.net/amo and always had great results 98% of the time.Princo is the media i go with,cheap but reliable.
Now its time for me to get a new DVD-RW drive and i've been looking at the NEC ND-1300A writer at newegg for $102.My question is does this drive work well when it comes to burning Princo DVD-R media?
My neighbor's Nec1300 doesnt like Princos
cdfreaks.com says the Nec2500 (8x) writes them excellent and its about 120 bucks -
When you say the drive does not like princos,do you mean it won't burn them at a certain speed or won't work with them at all? I've read articles saying it would only burn certain media like princo at 1x/2x instead of 4x.Originally Posted by tompika
Anyway i'm not THAT picky about speed.If it burns the discs at 2x without problems i'd be happy. -
Also what about the LiteOn LDW-411S writer,does it handle princo media well?
http://www.newegg.com/app/ViewProductDesc.asp?description=27-152-011&depa=1
NEC 8X DVD+RW/-RW Drive, Model ND-2500A, OEM Bulk
Price: $117.00
Read the bottom of the page first
http://www.cdfreaks.com/article/134/7 -
My 411S burns Princo just fine.Originally Posted by Star Warrior
I have the Iomega burner, which is a nec1300. Compusa 1X -R, which are princos, burn at 2x just fine.
well just wait till you burn past 4gb and try play dvd movies you copy on home dvd player with them you will get problems, well i did i never buy them again sticking freezing after 4gb mark. i only buy Ritek G04 now
media drives
By c-raig in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2010, 05:13 -
Question about either of my Sony drives being able to burn dual layer discs
By Puppets86 in forum DVD RippingReplies: 51Last Post: 9th Jun 2010, 19:04 -
What is the best DL media for Pioneer 1810 and DVR-710 drives ?
By MacPCConsultants in forum MediaReplies: 9Last Post: 2nd Dec 2007, 14:37 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 14:13
