CAN ANYONE HELP ME !!!!!!!!!!!!!!!
I'VE GOT A DVD THAT I TRIED IN MY STANDALONE PLAYER AND IT PLAYED LOUSY PUT IT MY P.C AND PLAYED IN POWER DVD AND IT PLAYED PERFECT THEN I NOTICED THAT POWER DVD IDENTIFIED IT AS AN MPEG.
FROM THIS I PRESUME IT IS NOT IN A STANDARD DVD FORMAT DOES ANYONE KNOW HOW I CAN CONVERT THIS DISK TO A STANDARD DVD FORMAT FOR MY STANDALONE PLAYER.
Results 1 to 10 of 10
You need to explain yourself a little better,
when you say it played lousy, what exactly do you mean - was it jumping or skipping / bad picture / lots of flickering, what? -
freezes after a minute and there is virtually no sound but it is absolutely perfect on p.c i think it is a problem with the format not the dvd player all other dvd's play fine .
Have you used this particular brand of media in this particular dvd player before? My standalone player plays many types of dvd-r media poorly.
File : 1023 MB (220 MB), duration: 0:22:25, type: MPG, 1 audio stream(s), quality: 63 %
Video : 184 MB, 1150 Kbps, 29.970 fps, 352*240 (2.21:1), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 35 MB, 224 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported -
I have somewhat the same problem. I copied a home video miniDV to, via firewire, my new Liteon DVD recorder. I have no sound on my stand alone player, unless I change output set on the player to PCM. Here's the AVIcodec info: V. codec name: MPEG 2 (SVCD/DVD)
A 1 codec name: Mpeg-1 audio layer [0xc0]
File : 44 MB (0.0 B), duration: 0:00:00, type: MPG, 1 audio stream(s), quality: 98 %
Video : 0.0 B, 9450 Kbps, 29.970 fps, 720*480 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 0.0 B, 256 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
Is the audio not compliant for DVD, if not how can I change it
DVD to MPEG Conversion
By Exodus119 in forum Video ConversionReplies: 2Last Post: 26th Feb 2010, 19:06 -
MPEG to DVD VIDEO-TS conversion
By efiste2 in forum Video ConversionReplies: 4Last Post: 7th Jun 2009, 16:08 -
AVI to MPEG conversion and DVD burning
By mc-help in forum Video ConversionReplies: 2Last Post: 5th Jan 2008, 16:08 -
DivX to Mpeg -> DVD Conversion is Jerky
By jedijfo in forum Video ConversionReplies: 4Last Post: 15th Oct 2007, 08:32
