I ripped the movie The Core using dvd shrink and all of the files came out fine, but where the layer switch on the dvd shows up the movie stops and the screen goes blank. I then have to use the chapter forward button on my remote to get the movie to continue. Is there a way to get the movie to coninue playing seamlessly through the layer switch?
Under EDIT- PREFERENCE- OUTPUT FILES: make sure Remove Layer Break is checked.
That option is checked.
For some reason the movie pauses like it would for a layer switch, the screen goes black, then I have to chapter forward to get it going again. Shouldn't the movie just continually play?
PotPlayer: no audio switching, no subtitle switching
By WinDVD_5_platinum_fan in forum Software PlayingReplies: 1Last Post: 6th Oct 2012, 22:44 -
Problem: DVDShrink > DVDDecrypter - Layer Break Issue?
By Dave Stewart in forum DVD RippingReplies: 32Last Post: 27th Jun 2010, 21:18 -
How to DVDshrink 7GB of video to DL DVD that handle layer break ?
By SingSing in forum Newbie / General discussionsReplies: 3Last Post: 25th Apr 2010, 16:53 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00
