I have searched this site for more information about these two programs. Which one is better for encoding? They both seem to do the same but TMPGEnc has more functions in it, i suppose it should the better.
AVI2VCD seems pretty simple. For which type and/or length is it useful?
Is there any site where they tell more about these softwares?
Almost no one here use AVI2VCD, at least no one mention it.
To learn, how to use TMPG, have a look at the "how to..." section. There you will find a bunch of very good guides. For example these ones:
http://www.vcdhelp.com/tmpgenc.htm
http://www.vcdhelp.com/dvdtovcd.htm
http://www.vcdhelp.com/tmpgencedit.htm
http://www.vcdhelp.com/tmpgencexplained.htm
Always usefull: http://www.vcdhelp.com/faq.htm
<font size=-1>[ This Message was edited by: Truman on 2001-10-18 17:06:44 ]</font> -
In my case I use TMPGEnc because it is so much faster (a couple hours for a standerd movie) than avi2vcd (many many hours) Converting the movie audio to wav. with virtualdub before plugging it into TMPGEnc also speeds up the process.
I hope this helps you alittle.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
