I have some Fujifilm DVD+R, and it is RICOHJPN.Originally Posted by mro
Results 31 to 41 of 41
The dvd-r's are on sale for the same price also, so I picked up a spindle today. The only kind of identification I can pull off the disc is:
Manufacturer ID: TDKG02000000 - which doesn't really tell me anything other than they are TDK discs - or does the G0200... mean anything? I burned a couple and they worked fine, and for this price I'd like to pick up a few more, but I'm a little hesitant to do so without knowing who the actual manufacturer is. Can anyone identify this code?
Thanks,
Roy -
TDK makes TDKG02 if in a TDK official caseOriginally Posted by godbeerWant my help? Ask here! (not via PM!)
Thanks for the info - I didn't think TDK manufactured their own discs, I though they were all rebranded discs from other manufacturers (such as those mentioned above).Originally Posted by lordsmurf
One guestion - what do you mean by "official case"?
Thanks,
Roy -
Thanks for the detailed pictures..
By using them, I was able to pick up the only 25pack of non-CMC packs in my local Best Buy.
Good burning to alll....
Go PanthersThe OldeMan -
MRO, Thank you so much for all your investigating! It's been imposable until now to be able to identify this media. This is going to make DVD shopping a whole lot less stressful for me!
Well, I am not out looking for the RICOH because they don't burn as well in my LitoOn 811s as the Verbatim Datalife Plus DVD+R 4x (will burn at 8x) made in Singaporr. Check out some of these...they are $34 for a 15 pack at Office Depot.Originally Posted by dglwow
Been through about half my 25 pack of CMC TDK's DVD+R, first half burned fine at 4X, now the secong half has stared to give me some coasters. Trying to burn them at only 2.4 X now.
Burned 18 of my 25 CMC's so far no coasters, anyone else writing these at 8x? mine start at 4x then towards the middle they hit 8x
The different in the plastic ring also apply to Memorex. It is a very good observation but it is impossible to tell in the Memorex case because Memorex spindles are covered with the warning of firmware upgrade in the top.
Can't burn DVD using TDK burner
By tee jay in forum MacReplies: 7Last Post: 16th Sep 2008, 15:01 -
TDK DVD+RW format before use
By nobbydadog in forum MediaReplies: 2Last Post: 30th Apr 2008, 09:55 -
TDK Professional DVD-R media ID?
By lordsmurf in forum MediaReplies: 4Last Post: 15th Dec 2007, 12:08 -
Sony and TDK DVD Discs
By Happs in forum MediaReplies: 14Last Post: 29th Jul 2007, 15:43 -
TDK brand DVD+Rs- These any good?
By Super Warrior in forum MediaReplies: 12Last Post: 28th May 2007, 15:19
