I check up on it every once in a while. Doesn't seem to be updated very much (at all?). I wonder what the feasibility of anyone looking at the code and figuring out a way to make it faster (my main complaint). It is an awesome multiplexing tool as well. But, how does it get away with encoding MPEG2 as freeware? I thought you had to pay some licensing fee to do that?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 10 of 10
fmctm1sw,
What are your intensions w/ bbmpeg ??
To code some front-end to it, or just use it as is ?
I coded a front-end to it some time ago, but I haven't updated it (as I had
planned) too many things going on at once. I was meaning to code some
thing a little smaller w/ D'nD for ease of use though - if time ever allows.
-vhelp -
if someone is looking for a free mpeg encoder, you should look into ffmpeg. ffmpeg is widely known for its audio encoding ability, but it also can encode to mpeg1/mpeg2.
Documentation can be found here:
http://ffmpeg.sourceforge.net/ffmpeg-doc.html -
there are actually several ways to compile ffmpeg for win32. Baldrick is kind enough to provide a cygwin build in his ffmpeggui that he wrote.
ffmpeg can also be compiled with msys and mingw. (type ./configure then type make)
Correction: Baldrick's isn't compiled with cygwin, but im fairly sure it could be done if needed. -
Originally Posted by vhelp
https://www.videohelp.com/download/ffmpeggui02c.zip"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
my appoligies guys.
I forgot about Baldrick's ffmpegGUI port - - I ment, to say,
"besides" Baldrick's ffmpegGUI port hehe..
From what I read, ffmpeg does audio processes. I think I read, after searching
through the internet highway that ffmpeg also encodes to mpeg-1
and mpeg-2. I was mainly seeking these processes.. in my quest to finally
come up w/ an MPEG-2 cutter/joinger app to code (even if that ment to code
a front-end)
In my search, I found a port, "mpgtx"
I found mpgtx to be pretty good (for the limited amount of time I have
spent w/ it (yesterday) I am planning on posting something (if worth while)
soon, here on vcdhelp. Something I've ben looking forward to doing for a
very long time :P All I need is a good name
At this time, I'm coding a Delphi front-end to this port - my head hurts from
all this fun
Thanks guys for your help and all,
-vhelp -
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2011, 23:59 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 05:45
