i have a collection of videos that are both mpg and avi... to burn them all to dvd i have to convert the avi ones to mpg... i only have 2 programs pinnacle studio 8 se and tmpgenc.... whats the easiest way to convert these avis to mpg without alot of programs and hassle
I too have both programs. I have been using Studio 8 SE for about a month or so now and have had no problems with letting it encode the avi captures to mpeg-2 and then burning them to DVD. Not one coaster yet! TMPGEnc will also do the same process, although I think only the Plus version supports MPEG-2, don't know which one you have. It is really a preference thing for me. Pinnacle may take a little longer, but all files can be contained in one program, you don't have to jump from using one program to the other. And I have had no problems with Studio 8 SE. Keep checking out the site, there are some great guides here to help you with everything that you need!
cant you give an easy way to do it in pinnacle then? i havent found it anywhere in the help
You can input those clips I believe in the capture tab or edit tab and then you can go to the "make movie" tab and output them to an mpeg file. You should have that option in the "make movie" area. It may take a bit of time, but eventually it will convert your avi files to mpegs.
I would convert them all through tmpgenc first.
I agree, tmpgenc is very user friendly.Originally Posted by hardcoreruss
SLICK RICK
Easiest way to convert and mux audio to raw avi
By mukluk909 in forum AudioReplies: 4Last Post: 30th Nov 2010, 04:08 -
Easiest software to convert Dual Audio/Subtitle MKV to WMV or AVI
By greasyspoon in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 13:43 -
What is the easiest program to convert MKV to AVI (without audio)
By Mylo in forum Video ConversionReplies: 2Last Post: 22nd May 2009, 17:52 -
Newber: easiest solution 2 convert dvd (aud/vid .ts) from HD to NAS in MPG
By gizfs in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2008, 19:27 -
Need To Convert VOB 16:9 to 4:3 AVI or MPG
By hjordan in forum Video ConversionReplies: 1Last Post: 6th Oct 2007, 22:17
