Hello All,
First of all, I wanted to say that I really did try to find the answers to all these questions by searching this (and another) forum, but I had to go through hundreds of hits... so I thought I'd jst ask.
I have a Mac G4 dual 500 running Panther. I'm just getting started with DVD. I have a strong audio background, my wife has a strong digital video backround, and together we're gonna make some DVDs....
...if I can figure out which model, formats, and software. So, if any of you use a Mac to burn DVDs, and if you could be so kind to share you experiences with me, I would very much appreciate it.
These are my goals:
1. Burn DVD's to backup data.
2. Create simple DVDs via iDVD (or something similar).
3. Create more complex DVDs with DVDSP2.
My questions are:
1. Any advatage to the different formats when burning data CD's for file backup?
2. Apple's site states a SuperDrive is required for iDVD. So what is another simple DVD authoring program you gurus suggest for Mac? I've seen a few mentioned, anyone havea favorite?
3. What drives are compatible with DVDSP2? Anyone using DVDSP2 with their Mac and thrid-party drive?
4. Is anyone doing all three of these things with their burner, and does it not do one or more of these things well?
Thanks in advance for any help.
Dave
Dave Crane
http://www.pearlalleyband.com -
1. Any advatage (sic) to the different formats when burning data CD's for file backup?
4. Is anyone doing all three of these things with their burner, and does it not do one or more of these things well? -
Hi PJM,
Thanks for the suggestions and info.
Anyone else have any info to add about drives?
Cheers,
DaveDave Crane
Any MIDI gurus around here?
By sdsumike619 in forum ComputerReplies: 19Last Post: 26th May 2009, 00:49 -
Any MIDI gurus here? re: SCD-10
By sdsumike619 in forum AudioReplies: 0Last Post: 22nd Oct 2008, 22:35 -
Any Hardware Gurus Out There: I'm trying to install OS on AMD64
By wiseant in forum ComputerReplies: 9Last Post: 6th Mar 2008, 01:11 -
Any gurus here that know how to capture SWF from the web?
By sdsumike619 in forum Newbie / General discussionsReplies: 18Last Post: 6th Feb 2008, 21:53 -
Question for NR gurus...
By takearushfan in forum AudioReplies: 11Last Post: 28th May 2007, 19:00
