What is Block Noise?
I'm doing capture thru firewire (as avi) and I notice these rectangular blocks in the video especially when there's alot of motion. I assume this is "block noise" right?
I'm using TMPGenc to convert to mpeg. What's the best way to reduce block noise in TMPGenc? From reading other posts I see people recommending that VBR is best for reducing block noise (and checking "soften block noise" checkbox - what are the best settings for the "intra block and Non-intra block" boxes?)
Patrick
yep, thats block noise, when you see this, it is in the converted mpeg not the captured avi, right?
you don't say what your final output mpeg has been converted for - dvd/vcd/svcd.
if it's vcd then block noise is common in fast motion scenes, although there are filters that soften them
either way you probably need to raise your bitrate -
Yes, it's in the converted mpeg. The final output is going to DVD - first thru showbiz for editing then thru "TMPGenc DVD Author" for authoring.
Last night I tried a few special settings in TMPGenc Plus intended for elimination of block noise on a 90min tape. When I went to sleep it showed it had 10hrs to go. Woke up this morning and it showed it had 9.5hrs to go. In other words, as of this morning, TMPGenc was going to spend 17hrs encoding a 90min tape from avi to mpeg2 (My PC is only an Athalon 1.2Ghz but 17hrs is still rediculous ).
Patrick
Originally Posted by curryman -
Some poeple say they like to capture S-Video with DV. S-Video will give it a software look.
Never knew that, will give it a go, got some film which seems to sharp after conversion i'll see if it improves itSome poeple say they like to capture S-Video with DV. S-Video will give it a software look.
remove noise and block.
By mathmax in forum RestorationReplies: 124Last Post: 21st Mar 2014, 15:51 -
To block sites
By Jomapil in forum ComputerReplies: 13Last Post: 24th Apr 2012, 19:12 -
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 19:42 -
Multi-colored block noise bug in Adobe Premiere - DV video
By tat2jr1 in forum EditingReplies: 0Last Post: 23rd Jan 2010, 02:20 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57
